    Help to get started
    4 Posts 3 Posters 403 Views 3 Watching
      lemuzz
      Hi I am having trouble getting started. Would someone please run me through the following: I want to draw a channel made from 2mm mild steel. 230mm long 50mm high and 50mm deep. On the 2 legs a matching slot 140mm X 10mm (each side)starting 40mm from an end,and 35mm from the bend and on the top face a 10mm hole on the centre Thanks Lem 😍
      • MALAISEM Offline
        MALAISE
        Hi Lemuzz
        I hope I've understand your need. Here is a small down and dirty model. What about legs ? (Technical english may differ
        from what I think )
        MALAISE 😄
        channel.skp
          lemuzz
          @malaise said:
          Hi Lemuzz
          from what I think )
          MALAISE 😄
          yes this is what I want. But with a slot on each leg and a hole on the remaining surface. Could you run me through how it is done? Thanks Lem 😎
          • Jean LemireJ Offline
            Jean Lemire
            Hi Lemuzz, hi folks.
            See attached SU file for ideas.
            Channel with slots and hole.skp
