    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 216.4k Views 65 Watching
    • jeff hammondJ
      from a different thread but it's about this plugin
      @chris fullmer said:
      And Jeff, why is your perpendicular face tool icon so tiny? That's kind of weird. It should be the normal size.
      it's because the resolution is set to 300 and all the other icons are at 72.. for some reason, SU mac is reading the actual document size instead of the pixel dimensions when displaying the icons in the custom toolbar.. strange
      i have it sorted out now but i guess in the future, make sure they're at 72 ?
        magazines
        I'm a bit of a newbie. I have been trying for hours to produce a plane that is perpendicular to a line (a sight line actually). I tried to access your plug-in which seems to accomplish this task wonderfully, but it said I did not have permission. How could I get a copy? Thanks very much for the writing of the plug in.
        Brandon
        • Chris FullmerC
          It said you didn't have permission when you tried to download it? or when you tried to run the plugin?
            magazines
            Hi Chris,
            Thanks for the response. It's odd, I got the plugin to download after re-registering.
            But even when I put it in the plugins folder, it doesn't show up under my plugin pull-down menu.
            Strange. I'm sure I'm doing something very stupid, but at the same time I've tried it different ways.
            Any ideas? It certainly seems to be what I'm looking to do.
            Thanks,
            Brandon
            • Chris FullmerC
              I file it under Plugins>Chris Fullmer Tools> Perpendicular Face Tools. Let me know if its not there,
                magazines
                Well,
                I think there we have a difference of platforms. I'm on a mac and the plugins go in a folder under application support for Sketchup. I think I have it in the right folder.
                When I open sketchup (upgraded to 7) I get the following message:
                no such file to load -- clf_perpendicular_face_tools/clf_perpendicular_face_tools.rbError Loading File clf_perpendicular_face_tools_loader.rb
                I'm really not sure what is happening. Also I tried another plugin on the forum, and it worked.
                Thanks for any suggestions.
                Brandon
                • jeff hammondJ
                  when you download the plugin & unzip the file, you'll have a folder called
                  clf_perpendicular_face_tools_v1_2
                  open that folder and you'll see two items:
                  clf_perpendicular_face_tools_loader.rb & a folder called
                  place those two items in your sketchup plugins folder and start SU..
                  the path should look like this:
                  (click on the picture for larger)
                  note the two items i listed above are in the plugins folder.. the actual ruby is inside the clf_perpendicular_face_tools folder.. leave it there along with the toolbar icons.
                    magazines
                    Thanks Chris and Jeff,
                    I downloaded it again, and finally got it to work. For some reason it was automatically creating another folder within the clf_perpendicular_face_tools folder. So I guess it wasn't seeing the ruby.
                    Thanks much, It looks like this tool does exactly what I need.
                    Thanks for helping out someone getting started.
                    Brandon
                    • Chris FullmerC
                      Oh good, glad you got it working,t hanks for helping Jeff. I'm pretty useless with Mac info.
                      And check this script in the future. I'm busy right now with school, but in the not to distant future this is a script that I have a few planned tweaks, includingbetter Mac support (I think the rotation keys might not work on a Mac if I remember correctly), and letting the custom face use a point other than its center point. Both are easy enough to implement, I just need to do it. So like I said, check back on this plugin in the future, and hopefully it will be even better,
                      • broomstickB
                        broomstick
                        Chris, I never got to thank you for this script. It is a time and life saver when fast modeling stair railings!!!!
                          driven
                          Hi Chris
                          the link appears to be broken, I've downloaded a couple of your others before and after getting "you do not have permission"
                          html instead of this file, I'll try again next session, but it may need re-posting from your end.
                          It looks great, and I do like your videos...
                          • Chris FullmerC
                            Hi John, the link is good. There have been reports of some people have issues downloading files from the sketchucation forum. I don't know if aynone has ever figured out what causes the error though. Please try to download it again. If it still is not working, let me know and I'll upload it to another place where you could download it. Just let me know either way,
                              driven
                              Hi Chris,
                              Came down this session on second attempt (using a different download manager)... No idea why...
                              This site may have Safari issues, Auto Login doesn't always work, and tab browsing seems to have me logged in at one page, but not another.
                              It's not consistent so I can't quite figure out what's happening...
                              I'll try these plugins now
                              cheers
                              John
                              • kenK
                                ken
                                I noticed that “Perpendicular Face Tools” (PFT) will make squares that are in factions of an inch, such as 10 1/4" per side, however the circle tool always seems to round off, 10 1/4” becomes a 10” radius.
                                Was this intentional, or is it an error with my computer?
                                Would be nice if the circle tool would operate with factional inches.
                                Thanks for all you plugins.
                                Ken
                                • Chris FullmerC
                                  Interesting, thats a good catch Ken. I tihnk its a bug.
                                  Also Ken, I am remembering you said you had two "Chris Fullmer Tools" menus. Is that still the case? And if so, do you mind listing what plugins are in each? I'd like to fix all that at some point.
                                  • kenK
                                    ken
                                    Thanks for remembering. However, it has changed from the original. It went to one menu item during one of your scripts install to now again two menu items. I have just learned to live with it.
                                    Here are the two menu items as of now.
                                    First Chris Fullmer Tools
                                    1. Center on origin
                                    2. Shape Bender
                                    Second Chris Fullmer Tools – Well I’ll be darned, I have two Shape Benders. I never noticed that there was a duplicate menu item.
                                    1. Components onto Face
                                    2. Label Open Edges
                                    3. Scale & Rotate
                                    4. Select Lines by Length
                                    5. Shape Bender
                                    6. Loose Geometry to Groups
                                    7. Perpendicular Face Tool
                                    8. Line Tool
                                    9. Arc Center Finder
                                    10. Simple Loft
                                    11. Extended Standard View
                                    Also, Chris thanks for the tip on how to arrange menu items by adjusting you window size. So far it works great.
                                      Suggestion (but seems very useful) 😉
                                      perpendicular face tool with selection of some lines !
                                      So no need to click line after line!!! 😎
                                      • Chris FullmerC
                                        I like that idea. That is one to implement on the next round. I'd also like to have better support for perpendicular lines coming off of simple arcs and circles.
                                        I realy need a feature request tracker so that I have them all together for when I get ready to re-write some of these scripts! THanks for the great suggestions everyone, on all my scripts.
                                        • P
                                          publied
                                          nice job! very useful plugin. thank you.
                                          hire me@ http://www.publied.it !
                                          • utilerU
                                            utiler
                                            Hi Chris, another idea....
                                            Have you considered adding components and groups to this tool? as with your custom face tool, another option that I think people would find 'components perpendicular; tool handy....
                                            Maybe another tool though as this is a 'perpendicular face' tool after all.
                                            Cheers,
                                            Just Curious...
                                            • 11
                                            • 6 / 11
