    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • Chris FullmerC
      Sorry Jeff, I just don't see how its possible at all. At least, not so that it would work with any regularity on more than a small handful of objects.
      But I do have a question, you say (in another post, and I'm paraphrasing) that the geometry is useless to you the way it currently is working. What are you planning on doing with the geometry after you bend it that makes it so useless?
      • jeff hammondJ
        i have to build it.
        pretty much everything i build is curved so in that regard, SU is a weird program to work with but the segmented curves aren't a big deal as long as key intersections/joints are at vertices... unless i go insanely high poly with the drawings, i can be out 3/4" or more which just isn't an option..
        also, if i'm colliding multiple curves then the resulting geometry isn't a radius or an ellipse and i have to plot points for construction... if those points aren't in the right spot, my measurements are off again..
        realistically, i have ways to build this stuff without drawing it first but by working through it on a computer first, i can do it more easily on site and/or have a way to show someone on my crew to make the cuts.. it's still faster for me to spend the hour or two on the computer getting my points in the right spot than it is to build without the drawings but if i can streamline the process even more then i'm not complaining πŸ˜„.
        [add] - as far as the actual drawing goes, there are problems as well.. these shapes are just shells and i often have to continue on to figure out the framing in tricky areas.. if the planes/lines aren't where they should be, it just doesn't work out too well.
        • Chris FullmerC
          Oh yes, now I remember the kind of stuff you use SU for. I think you need an entire plugin of your own for that skateboard park type work. That is definitely well beyond the scope of what I was thinking of with shape bender, as it would require a different type of bending calculation I think. Definitely better suited for a solid modeler or something. Sorry I can't be of more help at this point Jeff,
          • jeff hammondJ
            oh man, that would be nice.. if times were better, i'd be into paying for 2-3 custom scripts.. maybe in another year or two. :hope:
            ha, your plugins have already helped immensely.. i used to have to draw stuff like this line-by-line and being able to bend things now cuts more than 1/2 the time it used to take.. don't sweat it..
            you gotta realize that i know i'm asking for some weird requests that only I or maybe a handful of others would actually use πŸ˜„..
            just in case anyone else has the need to get the lines to break like this, i put a little step-by-step together...
            custom_arc_tut.skp
            i actually do it a little bit different than this (esp. steps 4-6) which is a little easier/less confusing but it was harder/more confusing for me to show how i do it.. this should get the idea across though.
            • W
              wolfy
              Chris, you are a machine!! (the good kind, of course)
              • Chris FullmerC
                Jeff, I want to emphasize a bug in the code since it might matter to you, since you are making shapes that get built. But the first and last angles might not be calculated the way you would expect - I suppose that depends on what you expect. The image shows the problem. Every sliced part of the model lines up correctly to the curve expect the two ends. That is because I am not actually finding that outer angle at this point. It is a planned improvement πŸ˜•
                So I thought you should be aware of that so that it doesn't cause you undue pain when you can't figure out why stuff is not lining up right,
                • jeff hammondJ
                  yeah, i noticed that.. i didn't realize it was a bug though and i more/less attributed it to being like using the follow-me tool on an arc.
                  here's a top view showing that problem:
                  the workaround (and the same workaround goes for shapebender) is to make sure there is some flat before going into the bend.
                  followme_problem.skp
                  i guess if you manage to figure out how to fix your bug, pass that info along to google so they can fix follow-me πŸ˜„
                  [fwiw - if you look at the skp titled bend2.skp a few posts ago, you'll see that i added the flat ends.. the flat won't affect the setup i do to get all the intersections to match up because there are no vertices on it.. if i add 4' of straight wall prior to bending, i'll also add 4' of straight line before the curve]
                    sepo
                    It seems make faces makes error but makes faces nevertheless. Here is an extract from the console.
                    Error: #<ArgumentError: comparison of Float with nil failed>
                    (eval):44:in >' (eval):44:in update'
                    C:/Program Files/Google/Google SketchUp 7/Plugins/makefaces.rb:146:in makeFaces14' C:/Program Files/Google/Google SketchUp 7/Plugins/makefaces.rb:140:in each'
                    C:/Program Files/Google/Google SketchUp 7/Plugins/makefaces.rb:140:in makeFaces14' C:/Program Files/Google/Google SketchUp 7/Plugins/makefaces.rb:163 C:/Program Files/Google/Google SketchUp 7/Plugins/makefaces.rb:163:in call'
                      dtrarch
                      I'm not sure if this is the core issue, but rotating the arc to mid segment works for this simple try.
                      Rotated_Arc-Bend.skp
                      • jeff hammondJ
                        dtr...
                        the problem with doing that is it throws off all the measurements.. the SU arc is only correct at the vertices -- not the midpoints of the segments.
                        http://homepage.mac.com/jeffhammond/.Public/scf/nogo.jpg
                        • I
                          ideas_arte
                          http://i89.servimg.com/u/f89/13/29/04/03/muchas10.jpg
                          Thank you very much..!
                          muchas gracias..!
thank you very much..!
                            dtrarch
                            Jeff
                            Got it and thanks.
                            dtr
                            • W
                              waltw
                              Draw line on red axis, build and group a cube, draw an arc all on the same plane. Select tool.
                              Can't seem to get by 'please select a single line on red axis' I don't know much about ruby but thought that the following info might be pertinent??Ruby console output.jpg
                              Line 165 refers to code snippet: @line_pointer = UI.create_cursor(line_cursor_path, 15, 2)
                              My cursor does not change in anyway. Supposed to??
                              I thought there might be a conflict with other scripts so I removed them all (other than progress bar) to test - no avail.
                              Using XP SP3, SU7
                              OpenGL problem? Any suggestions as to what to tweak?
                              Thanks, Walt
                              • Chris FullmerC
                                That sounds like it did not get installed quite right. There should a file called clf_shape_bender.loader.rb in the main plugins folder. Then there should be a folder caled "clf_shape_bender" and inside that folder should exist the files:
                                clf_shape_bender.rb
                                I'm guessing you might have ended up with everything in the main plugins folder. So manually create the clf_shape_bender folder and move all those files above into it, leaving only clf_shape_bender_loader.rb in the main plugins folders.
                                See if that is by chance the problem and let me know, thanks!
                                • Chris FullmerC
                                  I gotta admit, neither of those uses crossed my mind! They look great. I'm going to a cad manager meeting and I'm doing a presentation on Dynamic Components and Ruby. I'll be sure to include that example in my presentation!
                                    sepo
                                    Chris is there any solution to my problem yet?
                                    • GaieusG
                                      What I'd absolutely love (and don't get me wrong, Chris, this is a brilliant ruby in its kind anyway) is if the UV maps (say positioned texture and such) would keep their maps relative to the modified (bent) mesh. I.e. if the texture bent along with the mesh itself.
                                      Example: just imagine building perfectly textured arches in seconds.
                                      • massimoM
                                        massimo Moderator
                                        Many thanks for the plugin, Chris.
                                        It can make this...
                                        or this!!
                                        • Chris FullmerC
                                          Hi Sepo, thanks for reminding me. At this point, no, I've got nothing for that. It is odd that its the same error that most people get when they have a conflicting script. But you said you unloaded all other scripts and the problem persisted, right?
                                            sepo
                                            Yes that is correct. I have installed it my quad desktop with vista and it is really fine. I have also loaded it up on my laptop xp and it fine. It is only on this xp desktop which is making error. I can't work out why. I will go again through the plugins, but these are the same ones which I have on the laptop. I must point out the first version worked fine on the xp desktop . It is the last version I have problem with. It seems it has something to do with progress.rb but I do not know where to look. BTW plugin is awesome and I see much more use for it than simple bending. Using form to do transformations seems to give a lot of possibilities.
                                            • 63
                                            • 64
                                            • 6 / 64
