    Do SketchUp
    24 Posts 10 Posters 3.0k Views 10 Watching
    • B
      BTM
      i'll answer for him; sketchup gives shadow for the faces, no matter which parts are transparent or not.
      • N
        NewOne
        Uhm, so...those trees which drop shadow just for themselves are cropped from that rectangular face? david57 just used png file for transparency map, but the face is rectangular? I think I understand... he must notch around tree to have proper shadow.
        • david57D
          david57
          Ok thanks, marked001, for reminding me of this because i have forgoten some of this things since i havnt been using Sketchup for about 7 or 8 month.
          Ok, solo, Pngs are were made with the gimp from models that were made with ngPlant and rendered with kerkythea. Examles below.
          Ok, NewOne, Here's a simple sketchup tree tutorial that i should of used
          : http://www.aecbytes.com/tipsandtricks/2008/issue28-sketchup.html
          Exmples.rar
          • david57D
            david57
            I guess this is the way to go, is by making polygons around the tree
            with the line tool.
              rdluther
              Really cool trees... once you edge them out and hide the edges, these are going to give your trees a great look, they might be too nice and distract from you building, I don't have a problem with that because I am a landscape guy, but if you are a building guy this might be a little bit of a problem, just have to see when it all gets done. Great work.
              • L
                Luis Esteves
                Thanks for the tree tutorial david57 👍
                • david57D
                  david57
                  Another SketchUp.
                  • david57D
                    david57
                    Messing around with more background PNG's. Examples Here.
                    http://www.box.net/shared/buhutby5rn
                    • david57D
                      david57
                      Using an HDR on this one and a model for tree.
                        sepo
                        These trees are nice but I wish there is more tree trunk...they are bit short.
                        • david57D
                          david57
                          Thanks sepo, I keep seeing that the lower tree trunk is taller on T.V. and keep
                          forgeting to do that. Have been concentrating on the form or silhouettes and forget the
                          trunk size. Have to develop that skill.
                            sepo
                            I would say if you have about twice the length it would look better. Also a bit of varried thickness would be also better IMO.
                            • david57D
                              david57
                              Render is lacking, Computer doesnt have the muscle to do the job in a short time.
                              • david57D
                                david57
                                Another one but came out to dark.
                                • david57D
                                  david57
                                  I just had to fix the lighting.
