    Do SketchUp
    24 Posts 10 Posters 2.9k Views 10 Watching
    • david57D Offline
      david57
      Trying a background.
      • david57D Offline
        david57
        • RayOchoaR Offline
          RayOchoa
          can't wait to see a render of that. 😄
          CaR DeSiGnS bY mE
          http://ray-ochoa.com
          • david57D Offline
            david57
            Dont know if im going to render. Just a doodle.
            • EarthMoverE Offline
              EarthMover
              If you are not going to render, then why not hide the lines around the bounding box of the trees?
              Content Creator at Skapeup
              • david57D Offline
                david57
                Just thought the building looked to flat without edges.
                • marked001M Offline
                  marked001
                  I think they're referring to the lines around the planes the trees are mapped on.....not the building. You can hide any line on an individual basis..
                  http://www.revision21vis.com
                  instagram: revi21on
                  • soloS Offline
                    David, those are nice .png trees, where did you get them?
                    • N Offline
                      NewOne
                      nice trees! but why the shadow is rectangular? ❓
                        BTM
                        i'll answer for him; sketchup gives shadow for the faces, no matter which parts are transparent or not.
                        • N Offline
                          NewOne
                          Uhm, so...those trees which drop shadow just for themselves are cropped from that rectangular face? david57 just used png file for transparency map, but the face is rectangular? I think I understand... he must notch around tree to have proper shadow.
                          • david57D Offline
                            david57
                            Ok thanks, marked001, for reminding me of this because i have forgoten some of this things since i havnt been using Sketchup for about 7 or 8 month.
                            Ok, solo, Pngs are were made with the gimp from models that were made with ngPlant and rendered with kerkythea. Examles below.
                            Ok, NewOne, Here's a simple sketchup tree tutorial that i should of used
                            : http://www.aecbytes.com/tipsandtricks/2008/issue28-sketchup.html
                            Exmples.rar
                            • david57D Offline
                              david57
                              I guess this is the way to go, is by making polygons around the tree
                              with the line tool.
                                rdluther
                                Really cool trees... once you edge them out and hide the edges, these are going to give your trees a great look, they might be too nice and distract from you building, I don't have a problem with that because I am a landscape guy, but if you are a building guy this might be a little bit of a problem, just have to see when it all gets done. Great work.
                                  Luis Esteves
                                  Thanks for the tree tutorial david57 👍
                                  • david57D Offline
                                    david57
                                    Another SketchUp.
                                    • david57D Offline
                                      david57
                                      Messing around with more background PNG's. Examples Here.
                                      http://www.box.net/shared/buhutby5rn
                                      • david57D Offline
                                        david57
                                        Using an HDR on this one and a model for tree.
                                          sepo
                                          These trees are nice but I wish there is more tree trunk...they are bit short.
                                          • david57D Offline
                                            david57
                                            Thanks sepo, I keep seeing that the lower tree trunk is taller on T.V. and keep
                                            forgeting to do that. Have been concentrating on the form or silhouettes and forget the
                                            trunk size. Have to develop that skill.
