    Problem with groups
    5 Posts 4 Posters 558 Views 4 Watching
    • G
      geor1mk
      Hi, I'm currently working on a model created by someone who has recently left my office. My problem is that when I select a group to edit, all the other exterior entities disappear. It's a major issue when I'm trying to stretch a wall to match an ajacent one in another group or move a column to match an imported autocad elevation in another group.
      Usually, the way I've experienced working with groups before, the other outside entities just become grey, but are still visible. I'm assuming that this must be some sort of drawing preference, but I can't seem to locate it. I'm using Sketchup 6. Does anyone know how I can turn off this setting?
        remus
        if you go view->component edit->hide rest of model that should solve your problem.
        • boofredlayB
          boofredlay
          You can also set it and "Hide Similar Components" as keyboard shortcuts:
          I use these constantly.
          Go to Window > Preferences:
          • boofredlayB
            boofredlay
            And to change how "Grey" you want them to view;
            Go to Window > Model Info:
            • GaieusG
              I'd also "vote" for this as the identification of the problem. Also note that this is a "model level" setting (like applied styles for instance) so when you receive a file from someone else who uses these settings, it will be "in the file", not in your "general SketchUp settings" (that would be the Preferences window, not the Model info window).
