    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    New work
    14 Posts 10 Posters 645 Views 10 Watching
      gaganraj
      a few new sketchup pieces. modelled in SU and rendered in Modo. and lots of photoshop of course.
      http://i11.photobucket.com/albums/a155/santsephai/terrace_post.jpg
      http://i11.photobucket.com/albums/a155/santsephai/desert.jpg
        remus
        I havent quite worked out what i like about them, but i most certainly do like your images ๐Ÿ‘
        • soloS Offline
          Awesome images ๐Ÿ‘ , I can see on the bottom one what is PS and what is model as the transparancies overlap but the top one has me wondering.
          Can you quench my curiosity by posing your workflow or an image of the model, the render and the images you used in PS so I can get an idea of your technique?
          • boofredlayB Offline
            boofredlay
            Wow, very nice indeed โ—
            In addition to what Pete has asked, could you give a brief description of your SU to Modo import? Thanks.
              mateo soletic
              Fascinating images, well done. ๐Ÿ‘
              [Concept Illustrations](http://concept-illustrations.com/)
                gaganraj
                i'll get some process stuff up this eveing. thanks for the comments!
                • david_hD Offline
                  david_h
                  This is SKETCHUP?????? ๐Ÿ˜ฎ
                  Amazing. You're a Syd Mead Fan aren't you.
                    gaganraj
                    yeah, syd mead is in my blood. he's an alum of the same school I went to.
                    i've attached some process:
                    1. this image is for a car company. so the final image i posted in not the actual image, as i can't show you the concept vehicle. but I always start with a sketch. establisihing overall color, lighting and a little design.
                    http://i11.photobucket.com/albums/a155/santsephai/1-1.jpg
                    1. I do the sketch at the final proportion I want. usually close to 1 - 1.85 format. widescreen. Then I matte painted the BG.
                    http://i11.photobucket.com/albums/a155/santsephai/2-1.jpg
                    1. Photomatch my sketch painting in SU, and start to build over it. I'll usually go between 2d and 3d designing and redesigning till it all works.
                    http://i11.photobucket.com/albums/a155/santsephai/3.jpg
                    1. Then I bring my image into modo. I used the SU importer. Applied some procedural textures, GI, reflections, bumps and lighting. I have a script that will match the SU camera to the Modo camera.
                    http://i11.photobucket.com/albums/a155/santsephai/4-1.jpg
                    1. then composite the image in photoshop and add details - see final image.
                    let me know if anyone has any other questions! The SU - Modo transition is a bit hard, but i'm figuring it out...a SU/modo hybrid would be the perfect solution.... ๐Ÿ˜„
                    this image is pretty detailed and I had a lot of time to do it. most of my production work is looser. You can see some of it at http://www.totalrihal.com
                    cheers
                      boofredlay
                      Wow, thank you so much for the explanation. Simply breathtaking.
                      I am curious why you are modeling in SU and not in Modo. It seems this type of organic scene would be easier in Modo. But then again I am a Modo newbie so...
                        jasonh1234
                        Beautiful work. Thanks for the breakdown too.
                        Check out my SketchUp iconpack. Available here.
                          gaganraj
                          Thanks for the compliments.
                          I'm starting to model more in modo. I just understand my SU workflow so well, its difficult to make the shift. I'm struggling a bit with sub-d concepts, like having the right number of polys/loops to retain your models structure. But that is another issue. I really love SU's simplicity.
                          not to change the subject, but I was thinking if it was possible to somehow create a UV extension for SU.... kind of like vray is integrated into the SU interface, or even layout and style builder - i wouldn't have to learn modo! ๐Ÿ˜„
                          • N Offline
                            nomeradona
                            nice images. i notice that more and more people are approaching this kind of workflow.
                              Seems Richard is making that for lighting ๐Ÿ˜‰
                              And here solution ๐Ÿ˜‰
                              Your works are very astonished! โ˜€
                                JHuman
                                Amazing! I checked out your website as well, you do great work. Quite inspiring for me I might add.
                                • Doweth!
