    MotorSketch
    22 Posts 6 Posters 3.5k Views 6 Watching
    • W
      Wacov
      Thanks! Is it really that hard? 😲 I've been playtesting it too much! Jumping straight on the bridge is essential; I'll see if I can't make the landing easier. It's taken quite a while, but I enjoy making stuff like this.
      Good idea; breakable finish line should look great! What do you mean by the loop? Like a mini-track?
      • T
        Trimmer
        Very Nice!! Looks Kool!
        I Don't have a controller yet, can I controll it from the Keyboard?
        • W
          Wacov
          Sorry mate, it's too much hassle for me to add keyboard at this stage; I will eventually change the script controlling all aspects of the buggy so that keyboard and joypad can work, and if that's not possible I'll add a separate file; but only once the level is finished.
          • T
            Trimmer
            Thanks Anyway. Keep up the great work!
            • W
              Wacov
              Thanks. I am almost there, but I'd like to get a program to tile the textures I'm using, so I can compress them further without hurting the look of the game.
              • W
                Wacov
                So, so close now; there's a small track, the size of most SP games 😄 at the end of the main track. Everything to do with gameplay is basically there, the details that you see but don't play are what makes up the next 20%. Use previous link to get the newer V0.8
                • T
                  Trimmer
                  This is so Awsome!!! I cant wait to see what you do next!
                  I remapped the controlls to the key board just so i could see what you've done. I can not find a way to make it pas the jump though. maybe i'm missing something.
                  i'm going to get a controller today, will I need to install anything?
                  • W
                    Wacov
                    The jump is hard, but I expect you're just missing the boost 😄
                    It's mapped to the A button on the joypad. Change every 'a' in my script to key("space") to play. Again, the jump is hard... start boosting once you're on the straight, and don't turn too much or you'll miss. You shouldn't need to install anything, joypads are normally plug 'n play... but if it comes with software, install it. This, and most other SP games will work best with a 360 style pad, IE with analogue triggers.
                    Next I'll add some signs, to show you where to go when it's not that obvious... then I'll make a new map, I think muddier... jungle if SU can handle it... then more vehicles for both!
                    • T
                      Trimmer
                      Ohhh! 😮 Yea, Boost should help!
                      I picked up a controller, so now i can reset your controll codes and try again
                      Can't wait
                      • C
                        CPhillips
                        @wacov said:
                        :berserk: Thanks! Is it really that hard? 😲 I've been playtesting it too much! Jumping straight on the bridge is essential; I'll see if I can't make the landing easier. It's taken quite a while, but I enjoy making stuff like this.
                        I dont think it is too hard. Made it through on my next try.
                        I was thinking a loop the loop. You know, upside down. Might not be very easy tho.
                        • W
                          Wacov
                          Ah... I tried a loop in an early test track; because SU's camera doesn't like going upside down, it's very hard to control, and the camera goes crazy as you go up and come down.
                          • P
                            phy
                            that is realy good wacov
                            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                            • W
                              Wacov
                              Thanks everyone! What really annoys me is that the slowdowns as I increase the size and complexity are totally due to SketchUp's inefficient renderer. I've had to increase the simulation's framerate to compensate, and this destabilises the physics. The friction engine just gives up, so the buggy starts sliding at random intervals; I don't want to see the textures go though! Is it even remotely possible to use an open source game renderer, or a custom one, during the simulation??
                              • C
                                CPhillips
                                Possible. But a fair amount of work.
                                • W
                                  Wacov
                                  I've finally made version 1.0!! Replaced the wierd wooden curve thing, fixed the wheel wobble, and adden a few more objects to the track. There's now a proper image for it as well! I'm very proud of this thing, so have a play and tell me what you think:
                                  Error 404 (Not Found)!!1
                                  (sketchup.google.com)
                                  Some of the textures have been re-done; no more visible edges! The dirt and cliff textures were tiled using a program I got, and every last texture is from CGtextures.com (Thanks BTM!). I think the 8MB size is worth it, the textures really look good.
                                  • C
                                    CPhillips
                                    Amazing! Its a real polished game. Congrats Wacov!
                                    • W
                                      Wacov
                                      Thanks! But one thing I've been noticing is the drive and boost controls keep cutting out randomly. It kinda ruins it, but I didn't see anyone else mentioning it... is it just me? As far as I can tell there is nothing wrong with my scripts, and it used to work fine.
                                        MrPlanet
                                        What program did you use to tile them? That could really help me. 😄
                                        I reject your reality and substitute my own.
                                        • W
                                          Wacov
                                          It's called seamless texture generator. It's really easy to use, but I had to pay £45! I know about free ones, but they're way too complicated; this one blends the edges nicely, can remove highlights, and can do perspective correction and cropping. You can make textures any resolution you like, but the filesize gets pretty huge; which is bad for uploads. Again, it's £45, so not spectacular value; kinda depends on how much you're gona use it. Try the demo, it sticks a logo over the image you make, but you can see it working.
                                            Sgt.A.Johnson
                                            Anyone tried corel texture. i have it kicking around on a disc somewhere. Had it installed on an old machine and found it quite easy once you get hang of it. Not got it on my laptop and didn't have sketchup on old machine. anyone tried it with sketchup?
