    Use a face again
    3 Posts 2 Posters 578 Views 2 Watching
      jkiol78
      hello,
      i have a problem, because i have to make a face with not only line but also half circle. I want to use again this face on block for instance and for a follow me on a line made before
      How can i do to use when i want just only the first face i made?
      Thx you in advance
      Nicolas
      • GaieusG
        Hi Nicolas,
        There are sveral ways - depending on what you really want to use it for.
        First of all, you can make a copy of face easily by
        • double clicking on it (this will selet the face and its bounding edges)
        • Selecting the Move tool , pressing Ctrl and moving a "copy" of it.
          After selecting the face, you can also right click and make it a group so that you can handle it easier anfd it won't "stick" to other geometry.
        If you make a component instead, you can always insert this component into your model from the Component browser.
        In either latter case however, if you want to use the face as a profile for the Follow me tool - after placing it to the right place - you will first have to right click and explode.
          jkiol78
          thank you very much for your quick answer. i need to make a tunnel so i must draw the line and after follow it with my face. As a difficult face to make, i need to use again but not re-draw it all the time. So the best way to do this is to duplicate like you said me. it works perfectly!
          you can make a group too for the same results but i'm thinkig that it will be limitation for my model.
