    Best tree generation system
    27 Posts 13 Posters 6.7k Views 13 Watching
      Dryad free
      http://dryad.stanford.edu/images/gallery/image1_big.png
        Frecle free
        http://www.frecle.net/treed/treed_screenshot04_autumn.jpg
        • RichardR Offline
          Richard
          Frenchy - YOU DA MAN!
          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
            You too Richard, you too ! πŸ˜‰
            This curiosity for you πŸ˜„ Not sure it's work if you have not 3DCoat but...
            http://www.3d-coat.com/forum/index.php?s=78df26c2676dbaffc050c56a4bc2108e&act=attach&type=post&id=480
            http://www.3d-coat.com/forum/index.php?act=attach&type=post&id=510
            • david_hD Offline
              david_h
              Frecle free
              So I went to this link but I couldn't see where one actually downloads the software! it was a link to a forum that links to another forum . .etc etc? any help?
              Thx,
              D
                Hum hum πŸ’š
                You don't see the link following the images? πŸ˜’
                Maybe glasses is needing πŸ˜‰
                • david_hD Offline
                  david_h
                  No. . . I didn't see that. Merci.
                  ps. I do wear glasses. . .. apparently it's time for a perscription change.
                  • 2 Offline
                    2kemon
                    @frenchy
                    tree[d] is pretty cool in itself, but how do you use it with sketchup? I haven't been able to export a usable tree with leaves.
                      Try to find a prog who reload format DirectX or a converter then export in 3Ds or other compatible format with SU
                      Never try πŸ˜‰
                      • soloS Offline
                        If you export to .x (direct X) you can open with rhino, or Deep exploration can be used to do most conversions.
                        Just beware, the conversion to SU will be large.
                        http://img232.imageshack.us/img232/9357/selectoutputfilename.png
                        • 2 Offline
                          2kemon
                          Okay. I wasn't really aware of the use of the direct X format.
                          But like you're saying - if the the conversion makes the trees bigger than 1-2 mb, I might as well make my own trees.
                          I've been searching for a good workflow with trees and either kerkythea or indigo. But because of sketchups poly limit, I think kerkytheas proxy replacement option might be the best for fast results, and skindigos dummy components If I' going for an indigo render.
                          @solo
                          I've noticed quite a few renders you've made with vue. Are you using Xtream or Infinite? (Infinite is the standalone app, right?). And how do you find the sketchup -> vue work flow? I'm really interested in Vue, because of the seemingly unparalleled possibilities with trees and eco environments.
                          • romboutR Offline
                            rombout
                            hi all,
                            im running a mac with parallel desktop on it. I downloaded tree[d]. But when i try to open the program i get this error massage. "Unable to create 3D scene" does anyone know why? or how to resolve this problem
                              remus
                              Bit of a guess, but i dont think most virtual machines can access the graphics card on your main machine. If the app requires openGL or directX this could cause problems.
                              • soloS Offline
                                2Kemon
                                Sorry for the late reply, I seemed to have missed your post.
                                Both Infinite and Xstream are stand alone, the difference is Xstream can integrate with Maya, C4D and Max using other render engines like mentalray, vray, etc.
                                IMO you do not need any of them as the 'Complet' version has all the bells and whistles needed.
                                As for integration with SU, Vue 7 can import native SU files so you do not require SU pro to use it, however Vue does not recognise your groups and component structures so having models with hundreds of identical components in SU may seem light but as soon as it gets imported into Vue the all become unique groups which can explode into one huge taxing model, fortunately Vue can handle billions of poly's unlike SU.
                                • 2 / 2
