    Help with slanted roof/ceiling floor plan
    5 Posts 3 Posters 2.2k Views 3 Watching
      mocamro
      so I'm trying to SketchUp (is this a verb yet?) a floorplan that has low walls, and a slanted ceiling that peaks in the middle (think a-frame house, but not quite as steep), and am curious about the best way to go about it...any and all advice is appreciated
      TIA
      • E
        Ecuadorian
        404 Not Found
        (www.sketchucation.com)
        -Miguel Lescano
          mocamro
          @ecuadorian said:
          404 Not Found
          thanks Ecuadorian for the link
          I watched http://www.vimeo.com/2254304 to get an idea of what the plugin was about and I'm not sure that is what I need...I'm wondering more about the floor plan and the inside walls rather then the actual roof itself...I've been building them up, then crossing them with a diagonal line, and then push/pulling the extra stuff...is there an easier or better way then doing that?
            mocamro
            also, another, kinda related question...if I want to put in windows that aren't on the same plane as the roof, should I make them seperatly and place them on the existing structure, or should I try to build them in place
            TIA
              dtrarch
              Mocamro
              You can use the [project faces on a plane along vector] script.
              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_sections.html
              This will intersect a selected face with a sloping plane along a selected vector.
              Great for interior walls in rooms with sloping ceilings.
              dtr
              With your input, this post could be even better šŸ’—
