    Locking the move axis before starting
    15 Posts 6 Posters 1.5k Views 6 Watching
    • GaieusG
      So how is it working, Doug?
      • T
        Teezer
        Here's something I found helpful when moving objects in crowded spaces. Select the object first, then move the cursor out into an open area where there is no geometry to trigger inference. Then click the move tool, followed by the arrow key that defines the axis of the movement. Then move the mouse...
        Real life is just another website, albeit a rather boring one.
        • C
          caddict
          Thanks for that Gaieus and Teezer
          For me this should go in the duh thread!
          • GaieusG
            Well, it hasn't always been there. It was introduced in the Free (Beta) version of SU 5 some 3 years ago then was made available in the Pro version as well in SU 6. Quite many "pro" users were not used to it at the beginning.
            • C
              caddict
              Anyway, it's a very useful feature. πŸ˜„ Blender has a similar axis-locking function.
                Doug
                Good morning, sorry for the delay in replying, I was out of the office yesterday.
                Dosen't seem to resolve my situation. It may work in the three major axis but I am moving the objects in non major axis. Specificlly I am working on a machine sloped front panel, moving objests in non major axis directions. One problem is placing objects on the surface so I draw temp alignment lines on the surface and click to place the item on the intersection of these lines and that works fine, however if I need to withdraw it from or place deeper in this sloped surface it becomes very time consuming to do.
                I will try the withdraw and insert method for closely placed items.
                • F
                  fefillo
                  Doug,
                  You could try grouping those objects in the sloped face together, and then changing the orientation of the Axis inside the group: R-Click > Change Axes.
                  You can then align the group's axes to the sloped face and it will let you move the objects relative to that face. You may need to create construction lines to help you orient the axes (ie. a line normal to the sloped face to set Z-axis)
                  Hope that helps,
                  Fefo.
                    Doug
                    Fefo, I will give that a try, thank you.
                    Construction lines do seem to work the best and zooming in as tight as possible seems to help also.
                    Weird things happen if I try the Press the Sift key, sometimes the object jumps to another part of the screen and sometimes it just dissapairs.
                    Sometimes I've found it very difficult to start the object moving in the desired direction hence it would be really nice if you could just select the desired axis (red, green or blue) with assigned keys.
                    Doug
                      Jim57
                      If you were adjusting the placement of a gauge on an instrument panel, you could select the gauge and then select the Move Tool. Then place the Move tool on an edge or surface of the panel, click and slide it around. The gauge will follow the lead of the Move tool in three dimensional space, though at a distance.
                      Best,
                      Jim
                        Doug
                        Fifo & Jim.
                        Both your suggestions were very helpful regarding moving objects on the slanted surface. I was able to rotate the axis as well as slide it along the surface. Sliding didn't seem to work when I was using the Xray mode so I could see the hidden structure but with Xray turned off, did the job along with using construction lines for accuracy.
                        Thank you all.
