    Color by material?
    16 Posts 4 Posters 2.2k Views 4 Watching
    • X Offline
      xrok1
      why does color by material seem to not work everywhere in this file?
      • brodieB Offline
        brodie
        never run into that before. can you post the skp?
        • X Offline
          xrok1
          ok i slimmed it down enough to post it:
          PS its one of my earlier models so its probably something i did.
          • X Offline
            xrok1
            no, no, i want color by material. but its not working right.
              bubbalove
              Ohhh... I will take another look...
              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
              • brodieB Offline
                brodie
                I actually read that wrong too. I was thinking of Color by Layer. How do you do color by material?
                -Brodie
                  bubbalove
                  There was something wrong with the way the textures were applied or something. I re-applied all the textures and it works...
                  trailer.skp
                    bubbalove
                    Make sure you have all edges the same color in the Styles menu...
                    • X Offline
                      xrok1
                      THANKYOU very much BubbaLove, tell me you didn't have to reapply face by face. 👊 Please tell me how you did it?
                      • X Offline
                        xrok1
                        Oh, and is there a way to make the edge color more closely match the faces so they don't stand out so much?
                          bubbalove
                          The modeling was pretty simple and clean (in a good way) so I just selected everything that was one material and re-applied it with the paint brush. Only took a couple of minutes...
                          I don't think so...
                          • X Offline
                            xrok1
                            well, thanks again.
                            it is possible that its because the file was originally made in SU6, but who knows.
                              sintra
                              Just wondered what exactly you were meaning here as i have had this issue to 😉
                                bubbalove
                                There's nothing to it. I just selected everything that had one material and used the eye-dropper tool in the material window to select the texture he had been using. With everything highlighted and the right texture in my material window I just clicked on one of the highlighted parts and it changed it all to that texture. I can't explain why it worked really...
                                • X Offline
                                  xrok1
                                  Ahhhhhh! i just figured out whats going on. the edges and faces can each hold different colors. therefore if you paint your faces without their edges selected, the edges will remain black! you can also just select and paint edges a different color (see small cube) as long as edges color by material is selected in your style!! ☀
                                  this opens up some COOL possibilities.
                                    bubbalove
                                    Very cool! I'm glad you figured it out...
