    Ruby to organize plugins
    22 Posts 9 Posters 3.0k Views 9 Watching
    • BurkhardB
      Burkhard
      Below could be a field for selecting toolbars show/hide. Not all are needed everytime.
      http://www.ia-plus.de
      • Chris FullmerC
        Rick has a script that lets you put organize your plugins folder into sub folder and then each sub folfer becomes a sub-menu of your plugins folder and all scripts in that folder are listed in that submenu. It can be very helpful for organizing into groups. Script is found here:
        File Not Found
        (www.smustard.com)
        And I think he is working on a new and improved one because there is currently a lot of talk about doing something to standardize scripts and their origanizaion.
        And I noticed that his script is apparently only for windows currently......
        • Bob JamesB
          Bob James
          Super 😍
          Many thanks, Chris. Just what I was looking for.
          I've purchased and installed it on my PC.
          I'm primarily a Mac user, but I have SU7 for both Mac and PC.
          Rick: Looking forward to the Mac version 👍
          • Chris FullmerC
            Sweet, I'll be waiting on my commision check 🤣
            • Bob JamesB
              Bob James
              Now if I could just get it to work 😞
              File Organizer.rb is in the Plugins folder but I get the error message: "Error Loading File Organizer.rb"
              Using SU7 version 7.0.10247
              • Chris FullmerC
                Hmm, what does it say below that? THat is where the error messages are that help debug the problem.
                • Bob JamesB
                  Bob James
                  Chris,
                  Here's the whole error statement.
                    RickW
                    This is somewhat difficult to explain. There may be some folders in your Plugins folder that don't need to have their contents loaded by Organizer (Podium and Subsmooth are two that come to mind) - and in fact, trying to load their contents can cause problems (as you have experienced). Fortunately, there's a solution for that.
                    The .zip included a file called SmustardOrganizerExcludeFolders.txt. Open that and add to it any folder names that you didn't create as part of your organizing efforts. I suspect you may have a folder that includes "IDX" in its name. You would add that name to the .txt file. That will prevent Organzier from trying to load any ruby files in that folder and will thus prevent the error messages.
                    If you still have problems, let me know.
                    RickW
                    www.smustard.com
                    • Bob JamesB
                      Bob James
                      I put IDXRenditioner.bundle in the SmustardOrganizerExcludeFolders.txt file, but I still get the same error.
                      What's really strange is that IDXRenditioner.bundle is a Mac file for IDXRenditioner and is not, and should not be, in the PC Plugins folder. 😒
                      I've reloaded IDX Renditioner so I know it's the latest PC version 1.1.5.78
                      • jeff hammondJ
                        @daniel s said:
                        A good idea will be to have a webdialog and something like a filter to search the plugin.
                        Then with a double click execute the ruby.
                        Here I make a simulation:
                        this one isn't a simulation:
                        http://homepage.mac.com/jeffhammond/.Public/Find.mov
                        [edit] just in case the movie isn't clear as day: you can either choose the tool using that method or it will simply show you where it's at.
                        • jeff hammondJ
                          oh yeah.. it can do that too.
                          http://homepage.mac.com/jeffhammond/.Public/Find_that_too.mov
                          [note kerkythea tool bar next to the standard tool bar]
                          [edit].... and speaking of kerkythea... i'll try this on windows via x11... 😄
                          http://homepage.mac.com/jeffhammond/.Public/Benchmark.mov
                          • Bob JamesB
                            Bob James
                            Jeff,
                            Where can this be found for download/purchase?
                            • jeff hammondJ
                              Jeff,
                              you can buy it here..
                              Invalid URL
                              (www.apple.com)
                              just spend a few grand on their hardware and they'll throw the feature in for free. 😄
                              it's built into leopard.. it works with all apps... i see you also have a mac so try it out on there.
                              certain apps don't get that big of an advantage (photoshop for instance: the clone stamp tool is only in a tool bar and you can't navigate the menus to get to it so it won't show up in the search).. it works really well with sketchup however because all of the tools/actions can be found via the menus.
                              it's only searching the menus items and help files..
                                RickW
                                I put IDXRenditioner.bundle in the file, but I still get the same error.
                                The "SmustardOrganizerExcludeFolders.txt" file should only contain the names of subfolders in the Plugins folder, not specific files.
                                Please contact me at Smustard, as there are a few specific things I'd like you to try.
                                RickW
                                www.smustard.com
                                • Bob JamesB
                                  Bob James
                                  Jeff,
                                  Invalid URL
                                  (www.apple.com)
                                  Okay, you got me there 😳 Seems like a sucker punch though 😆
                                  Thanks, though, I'd not realized that the Help button would do that.
                                  • jeff hammondJ
                                    nah bob.. no sucker punch..
                                    i just found out about it 3 weeks ago or so when i finally upgraded to leopard and read one of those "99 hidden leopard features" type of articles..
