    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 571.0k Views 667 Watching
      Hi Ron,
      Let's see. First of all; specifying a precise value (of anything - not just the radius of a circle): what you see at the bottom right is now called the "Measurements box" (previously VCB: "Value Control Box" should you come across this term in older tutorials/references in the future). What you need to get used to is not to click into it when you want to enter a value but only start typing (you will see what you type) and when ready, pres Enter. With a circle, this value is the radius by default.
      Then make your tubes, position them accurately (across or just touching each other), select them, right click and in the Context menu go to Intersect > ...selected. This will create those "hand drawn like" lines and you can delete the uneeded part.
      To make different kinds and shapes of pipes, you will need to learn to use the Follow me tool
      Also, follow the instructions in the attached file to see what I mean (go through the scene tabs on the top. Note that the last part is shown in X-ray mode so that you can have a look "inside").
      Bent cylinder - 2 ways.skp
      Ah yes,before I forget; welcome to SCF! πŸ‘
        brandy20
        Hello everybody, my name is Luca, I live in Rome, Italy. I'm passionate about woodworking and I use SU for my projects. I've got a lot to learn anad I'm sure I will improve with you. See you!
        Ciao!
        Luca
          Hi Luca and welcome!
          Woodworkings? I have added you to the Woodworking usergroup (so you have access to the special forum "down there").
            Alias
            Hello everybody, my name is Tommi, I live near Milano, Italy. I am an architect and I have discovered from few the potentialities of SU.
            Of sure I will need your help to know better the program.
            Do I immediately take advantage for a first question of it, do you forgive me if they are not in the correct place, I can install together sketchup 6 and 7?
            Grazie e ciao
            Tommi
            • boofredlayB Offline
              boofredlay
              Welcome Tommi. I have SU6 and 7 installed on my computer with no problems.
              • O Offline
                ortzak
                Hi Im Edward fron the Phillipines and want to continue my education here in Sketchucation.
                Hope you will teach me more than anywhere else.
                Im currently in UAE working as a designer for an individual.
                More Power People!!
                  remus
                  hello Edward, fingers crossed you'll learn some useful stuff here πŸ˜„
                  • V Offline
                    viraj
                    Hello
                    It's been a dream to build/design in 3D and SU is what I was looking for - no pressure on the license fee, unless one is ready for it! No requests. Have a lot to learn and at 43 it's going to be even more fun!
                    Thanks, to all who have made this forum
                    Viraj
                      Hi Viraj and welcome! Believe me, 43 is not tooold for it.I'm at the same age and started SU only a couple of years ago. And with a name like yours ("Chopra"), you shouldn't have any problems with it! πŸ˜‰
                      Error 404 (Not Found)!!1
                      (www.aidanchopra.com)
                      • I Offline
                        iddqd
                        Hello. How can I get access to woodworking thread here? I`m using sketchup time to time (nothing seriously, just simple vis for video surveillance systems) for approximately 3 years and now I would like to try it for my woodworking project. πŸ˜’
                        sorry. i figured this out 😳 😳
                          rkitect
                          Hi there!
                          I'm neither new to Sketchup nor modeling, but I've never had the need to be involved with a forum for Sketchup. I am currently an Architecture student at Southern Polytechnic State University near Atlanta, GA. I am using Sketchup for a current class project and hope to get some advice from some seasoned users.
                          Thanks and I look forward to making new friends!
                            remus
                            Hello iddqd and rkitect, glad you found the woodworking forum iddqd.
                              And hi Carl (and welcome). It's not always the "need" for an involvement but one may find interesting ideas as well as unusual solutions so even an experienced modeller can find cool stuff in a place like this. Hope you'll enjoy yourself!
                                MKG
                                Hello all ...
                                I'm Mike, and I've been looking for an easy-to-use 3D modeller for a year now ... looks like I've found it! The reason for the search is a need to model my village church as it was when it was first built in the 11th century. I have the floor plan - now I have the ability to build on it without getting severe headaches.
                                I'm looking forward to this. Hope to get to know you all ... Cheers.
                                  Hi Mike and welcome. This sounds like an interesting and fun project. Seriously, I'm really looking forward to it. I've been doing things like that myself: http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=46 (although this should be some 14th century).
                                  And indeed, an early Norman ( ❓ ) church sounds more exciting than a decorated or perpendicular style Gothic one (there are lots of them anyway). πŸ˜‰
                                    MKG
                                    Thanks for that, Gaieus. I've looked at your church, and it's left me with my mouth watering. If anything was going to confirm I'd made the right choice, that church was it - and it appears to have a lot of Romanesque features, so I can learn a lot from it.
                                    Pretty good work!
                                    Mike
                                      On the main site (that we have just launched and will develop further) we are listing a bunch of tutorials (the number is growing day by day) among which I am now developing some with techniques for exactly Romanesque architecture (for a later, greater project). This one (for which you may need to register on the main site as well) is particularly about creating a cross vault.
                                      So just plunge in and I'll be more than happy to help with anything if you have questions (after all I am an archaeologist "by trade" πŸ˜‰ )
                                        Daggs
                                        Hey all, this is Daggs (Hello, Daggs), and I'm glad this board exists. Been evaluating other 3/2D CAD programs, they either suck or are uninspired. I'm looking to use SU to do some 3D drawring, then convert to CAM and finally G-code so I can run the CNC mill that I'm building. "But Daggs, why are you building a CNC mill?" I can hear you ask. Because, in the words of Sir Edmund Hillary, it is there. I'll figure out apps for the mill after I have it. Maybe kit furniture? We'll see.
                                        Anyway, on with the show. I'll be here a bit, I think, because this prog looks like something that is worth mastering.
                                        Daggs
                                          @daggs said:
                                          (Hello, Daggs),
                                          and welcome! πŸ˜„
                                          Indeed there are people who use SU to build physical models with CNC mills and you willprobably find some useful plugins (such as converting to stl format and such) useful here.
                                            buk2noy
                                            hi! everyone!? thanks for accepting me as a new member,
                                            seeking for peace of mind
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 72
                                            • 73
                                            • 15 / 73
