    Sky background - How To?
    8 Posts 5 Posters 724 Views 5 Watching
      Starlex
      Hi!
      I'v got one simple qst)
      What should I do, to get sky on the background of my model?
      Now I'v put sky texture rectangle behind the model
      Are there any other ways to get background?
        BUDLA
        @starlex said:
        Hi!
        Look this: http://www.youtube.com/watch?v=56NxdRXWoU4
        and this: http://www.youtube.com/watch?v=PO6vMQIusQI&feature=related
        It helping to set backrounds!
        Budla!
          Starlex
          So, your answer partially solved the question...
          Another one appears after I rendered model in Podium 1.6
          Why I don't see the background picture after rendering?
            BUDLA
            Look this topic: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=16953
            Budla.
            • david_hD Offline
              david_h
              Podium doesnt render watermarks or backgrounds. In order to do a sky you need to do a skybox, skydome or a sky billboard that and apply a sky image as a material.
                JamesD
                If you drag and drop an image into SU, you need to first explode the image before it will render in Podium. You could also import the image as a texture and scale it onto a face.
                  Starlex
                  Thanks to all! It's working now)
                  And another one qst: (I noticed, they all are about podium...)
                  In attach there is rendΠ΅red image:
                  Please, look at some strange details:
                  1. Strange lights under several surfaces - what is it? I'v got them whith some light/dark combinations
                  2. Take a look on rails - they are dotted at some places - how can I clean lines?
                  • honoluludesktopH Offline
                    honoluludesktop
                    Here is a sample (although needs better foreground) with IDX. Did anyone mention SU's watermark, or photo match (sort of).
                    IDX
                    Watermark
