    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 20.7k Views 20 Watching
      klaufi
      ah, ok, thanks^^
      You can do motors like you describe by setting the controller to:
      0.5-slider('motor')
      cool ๐Ÿ˜ƒ
      are there other commands you can write there?
        CPhillips
        ah, ok, thanks^^
        0.5-slider('motor')
        cool ๐Ÿ˜ƒ
        Yes. Lots.
        Try this with a servo to make it oscillate.
        Math.sin(frame/10.0)/3.0
        Or this to make it move once per second:
        Time.now.sec*(1/60.0)
          klaufi
          what are these commands and where can i find out more about them excited
          or are you writing something about them soon?
            sketchyman
            It doesnt work to me please help!! this shows me at the start
            Thanks a lot
            Sketchyman
            This is shown when i turn sketchup on
              sketchyman
              When are you planning to release the official version??
                sketchyman
                I installed skp6 and it works !!! great!!
                  sketchyman
                  Can you please post some instructions because the magnet somehow doesnt work to me!!! it just freezes and i have to turn it off. PLease help
                    CPhillips
                    I am changing it a little bit but when I am done I will write something up.
                    Basically Controller can be a little fragment of Ruby. So you can type in any legal ruby syntax that results in a number:
                    2+2
                    3*(15/2.0)
                    3.14*Math.sin(1.0)
                    You can even put stuff like
                    if frame<30 then 0.0 else 1.0 end
                    That will cause a joint to move to 1.0 after 30 frames.
                      CPhillips
                      Sketchyman:
                      -Sorry about the error on SU7. I have seen one other person have this problem but I dont know what causes it or how to fix it yet. If you manage to figure it out please let me know!
                      -Final version will be released when it is done. No specific date.
                      -See the magnets thread for instructions on the magnet. If you are still having problems post a description of the problem (and a model if possible) in that thread.
                        phy
                        Is their anyway you could add a concave hull.
                        Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
                          sketchyman
                          I tried to download thruster magnet model but its made with version 7.0 and i cant install sketchyphysics on that one. please post some models made with sketchup 6. thanks a lot
                            Sgal
                            I saw a video of SketchyPhysics 3 showing a piston linked to a normal cylinder. When activate the corrispondent slider, the cylinder seems to multiply.Is that possible in the current version?
                            http://www.youtube.com/watch?v=vNlhGt32oBg&eurl=http://sketchuptips.blogspot.com/2008/09/sketchyphysics-3-preview-video.html&feature=player_embedded
                              CPhillips
                              That feature isn't in yet. I have to figure out how to make it work with replay.
                                CPhillips
                                Sketchyman, could you try this to fix your SU7 error. Find the file win32api.so in your ...Sketchup 7\plugins\SketchyPhysics3 folder and copy it to just ...\plugins\ and see if that fixes the problem.
                                  CPhillips
                                  Nope, sorry.
                                  • X Offline
                                    xgraphica
                                    Sorry if this has been asked before (noob here) but I noticed v2 was mentioned as having Mac support at some undefined time in the future. Will this be implemented in v3?
                                    Cheers
                                    XG
                                      sketchyman
                                      I made this things You told me, but it doesnt even help. I tried to move it out completely, or give the file to both- sketchyphysics and plugin folder, and i also tried to leave it in just plugin folder, but nothing helps. I am sorry i couldnt help You.
                                        Sgal
                                        A bug (I don't know where it must be post, so I ad here): when I click on the piston joint, Internet Explorer says "script error"
                                        Cannone magnetico alfa.skp
                                          CPhillips
                                          Thanks Sgal. Fixed in next version.
                                            CPhillips
                                            Cheers
                                            XG
                                            Mac version isnt out yet. But soon.....
                                            • 3 / 5
