    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 25.5k Views 20 Watching
    • C
      CPhillips
      @wacov said:
      Lots of pretty annoying stuff is happening... the simulation starts, but nothing moves or can be moved, and then I can't cancel it and I have to close SU. I'm also getting pretty frequent bug splats and errors when I try to close the program. All I've done is get half-way through making a differential and started playing with magnets a bit.
      Can you give me steps to reproduce any of these problems?
      • W
        Wacov
        Sorry, I haven't been using it long enough to notice any specific triggers. I found out that the simulation not working was a result of gear joints not being on the top level group, but the crashes seem pretty random.
        • L
          l.frisken
          just search monkey lander on google and you'll find it...
          • X
            xrok1
            RE: frozen
            when i drop the big sphere (magnet) through the small spheres (frozen/magnetic),which are not on the surface btw, i would expect them to react to the force being applied. i can't attach the .skp cause its 94 meg. but i can post a better example if its not clear.
            P.S "magnetic" should be labeled ferrous it help keep things a little clearer.
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • C
              CPhillips
              @xrok1 said:
              RE: frozen
              Your saying you want them to unfreeze as soon as the magnet starts pulling them? Why not just leave them unfrozen it would amount to the same thing.
              Frozen means an object won't move until its touched. Magnets are not "touching" an object. If it didnt behave as it did all frozen objects would instantly unfreeze as soon as any magnet in the model started pulling them.
              If your model is 98megs it is probably because you have a bunch of animation stored in it. Try clearing it out with the Plugins->SketchyReplay->Erase option.
              It was labeled ferrous for a while. But everybody kept asking me what it meant. Magnetic is at least obvious if not totally correct.
              • X
                xrok1
                i was thinking for something like a car(magnet) rolling down a hill, where there are leaves(magnetic) so the leaves don't move(frozen) till the car comes into range. this could be sort of a fake wind simulation etc...
                • V
                  Verrou
                  Very cool update! Worth the wait. Maybe as an update to SketchyReplay, you could look at adding a speed setting, like 1/2 speed etc ๐Ÿ˜„
                  And also, it seems that sometimes (although it is happening more frequently) when using SketchyReplay, the objects don't go back to where they started :S Like so:
                  http://img15.imageshack.us/img15/4726/errorkn2.jpg
                  • K
                    klaufi
                    hello
                    i've awaited sp3 and now its there (kinda). yippie^^
                    i hope the bugs are quickly removed, for example the magnets arent working in my sp and it causes errors...
                    @cphillips
                    but i have another idea to aprove something about the keyboard controllers. i dont know how difficult it is to realize this, but it would be very cool:
                    you could put a tag near to the joint controls (or something you can additionally write into the controller line), so that the joints wont just move when you press and move back when you unpress. its better to have such an option if you want to build a robot or something like that, so that the servo or piston for example wont just move to his maximum when you press the button, but move and stops when the button isnt pressed. and in the case of motors it would set the speed up or down (i think im repeating myself...sorry)
                    motors with the zero point in the middle would also be cool. so if you move the slider left it moves forward and backward when you move it right. but i think you wrote something that this is planned for spIV, right?
                    ok, i hope that my wishes come true^^
                    • C
                      CPhillips
                      If you figure out a way to reproduce this let me know and I'll fix it. In the meantime you should be able to undo a few times and get back to normal.
                      • C
                        CPhillips
                        If you make the leaves out of boxes friction will hold them on the ground until the car is near.
                        • C
                          CPhillips
                          hello
                          I cant fix the bugs unless you report them. How do magnets fail? How can I reproduce the problem? Can you post a model?
                          • K
                            klaufi
                            that shouldnt be necessary...
                            when i make an object to a magnet and write some number into the strength field and then push on run nothing happens... it runs like normal, just the block is static and no force slider is there as it should be...and i cant get out of the run mode by reset, just by clicking on select or some other tool, but then the run button doesnt work anymore at all...and when i close su the pc shows me a message, that su doesnt work properly
                            after reopening su everything is normal again
                            oh, yeah, im using su 6
                            btw. i have found a solution for my robot joints:
                            i have made two motors in opposite direction, one set with slider and one with the key code (rightx for example), both with the same settings, so the one motor pushes exactly against the other until the one your controlling is stronger or weaker
                            heres an example (model downloaded from warehouse)
                            edit:
                            there are functions on both the arrow keys and wasd
                            and ive found another error: while running sp and puching some of the wasd buttons he sometimes leeves the run mode and selects the tools (A)rc or (S)cale
                            some experiment on a robot
                            • C
                              CPhillips
                              Ok, I know what causes that. Its when you enter a bad formula. Ill fix it in next release.
                              You can do motors like you describe by setting the controller to:
                              0.5-slider('motor')
                              Make sure the Control Panel window has focus when using the keyboard.
                              • K
                                klaufi
                                ah, ok, thanks^^
                                0.5-slider('motor')
                                cool ๐Ÿ˜ƒ
                                are there other commands you can write there?
                                • C
                                  CPhillips
                                  ah, ok, thanks^^
                                  0.5-slider('motor')
                                  cool ๐Ÿ˜ƒ
                                  Yes. Lots.
                                  Try this with a servo to make it oscillate.
                                  Math.sin(frame/10.0)/3.0
                                  Or this to make it move once per second:
                                  Time.now.sec*(1/60.0)
                                  • K
                                    klaufi
                                    what are these commands and where can i find out more about them excited
                                    or are you writing something about them soon?
                                      sketchyman
                                      It doesnt work to me please help!! this shows me at the start
                                      Thanks a lot
                                      Sketchyman
                                      This is shown when i turn sketchup on
                                        sketchyman
                                        When are you planning to release the official version??
                                          sketchyman
                                          I installed skp6 and it works !!! great!!
                                            sketchyman
                                            Can you please post some instructions because the magnet somehow doesnt work to me!!! it just freezes and i have to turn it off. PLease help
                                            • 3 / 5
