    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 21.4k Views 20 Watching
    • X Offline
      xrok1
      i was thinking for something like a car(magnet) rolling down a hill, where there are leaves(magnetic) so the leaves don't move(frozen) till the car comes into range. this could be sort of a fake wind simulation etc...
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
      • V Offline
        Verrou
        Very cool update! Worth the wait. Maybe as an update to SketchyReplay, you could look at adding a speed setting, like 1/2 speed etc ๐Ÿ˜„
        And also, it seems that sometimes (although it is happening more frequently) when using SketchyReplay, the objects don't go back to where they started :S Like so:
        http://img15.imageshack.us/img15/4726/errorkn2.jpg
          klaufi
          hello
          i've awaited sp3 and now its there (kinda). yippie^^
          i hope the bugs are quickly removed, for example the magnets arent working in my sp and it causes errors...
          @cphillips
          but i have another idea to aprove something about the keyboard controllers. i dont know how difficult it is to realize this, but it would be very cool:
          you could put a tag near to the joint controls (or something you can additionally write into the controller line), so that the joints wont just move when you press and move back when you unpress. its better to have such an option if you want to build a robot or something like that, so that the servo or piston for example wont just move to his maximum when you press the button, but move and stops when the button isnt pressed. and in the case of motors it would set the speed up or down (i think im repeating myself...sorry)
          motors with the zero point in the middle would also be cool. so if you move the slider left it moves forward and backward when you move it right. but i think you wrote something that this is planned for spIV, right?
          ok, i hope that my wishes come true^^
            CPhillips
            If you figure out a way to reproduce this let me know and I'll fix it. In the meantime you should be able to undo a few times and get back to normal.
              CPhillips
              If you make the leaves out of boxes friction will hold them on the ground until the car is near.
                CPhillips
                hello
                I cant fix the bugs unless you report them. How do magnets fail? How can I reproduce the problem? Can you post a model?
                  klaufi
                  that shouldnt be necessary...
                  when i make an object to a magnet and write some number into the strength field and then push on run nothing happens... it runs like normal, just the block is static and no force slider is there as it should be...and i cant get out of the run mode by reset, just by clicking on select or some other tool, but then the run button doesnt work anymore at all...and when i close su the pc shows me a message, that su doesnt work properly
                  after reopening su everything is normal again
                  oh, yeah, im using su 6
                  btw. i have found a solution for my robot joints:
                  i have made two motors in opposite direction, one set with slider and one with the key code (rightx for example), both with the same settings, so the one motor pushes exactly against the other until the one your controlling is stronger or weaker
                  heres an example (model downloaded from warehouse)
                  edit:
                  there are functions on both the arrow keys and wasd
                  and ive found another error: while running sp and puching some of the wasd buttons he sometimes leeves the run mode and selects the tools (A)rc or (S)cale
                  some experiment on a robot
                    CPhillips
                    Ok, I know what causes that. Its when you enter a bad formula. Ill fix it in next release.
                    You can do motors like you describe by setting the controller to:
                    0.5-slider('motor')
                    Make sure the Control Panel window has focus when using the keyboard.
                      klaufi
                      ah, ok, thanks^^
                      0.5-slider('motor')
                      cool ๐Ÿ˜ƒ
                      are there other commands you can write there?
                        CPhillips
                        ah, ok, thanks^^
                        0.5-slider('motor')
                        cool ๐Ÿ˜ƒ
                        Yes. Lots.
                        Try this with a servo to make it oscillate.
                        Math.sin(frame/10.0)/3.0
                        Or this to make it move once per second:
                        Time.now.sec*(1/60.0)
                          klaufi
                          what are these commands and where can i find out more about them excited
                          or are you writing something about them soon?
                            sketchyman
                            It doesnt work to me please help!! this shows me at the start
                            Thanks a lot
                            Sketchyman
                            This is shown when i turn sketchup on
                              sketchyman
                              When are you planning to release the official version??
                                sketchyman
                                I installed skp6 and it works !!! great!!
                                  sketchyman
                                  Can you please post some instructions because the magnet somehow doesnt work to me!!! it just freezes and i have to turn it off. PLease help
                                    CPhillips
                                    I am changing it a little bit but when I am done I will write something up.
                                    Basically Controller can be a little fragment of Ruby. So you can type in any legal ruby syntax that results in a number:
                                    2+2
                                    3*(15/2.0)
                                    3.14*Math.sin(1.0)
                                    You can even put stuff like
                                    if frame<30 then 0.0 else 1.0 end
                                    That will cause a joint to move to 1.0 after 30 frames.
                                      CPhillips
                                      Sketchyman:
                                      -Sorry about the error on SU7. I have seen one other person have this problem but I dont know what causes it or how to fix it yet. If you manage to figure it out please let me know!
                                      -Final version will be released when it is done. No specific date.
                                      -See the magnets thread for instructions on the magnet. If you are still having problems post a description of the problem (and a model if possible) in that thread.
                                        phy
                                        Is their anyway you could add a concave hull.
                                        Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
                                          sketchyman
                                          I tried to download thruster magnet model but its made with version 7.0 and i cant install sketchyphysics on that one. please post some models made with sketchup 6. thanks a lot
                                            Sgal
                                            I saw a video of SketchyPhysics 3 showing a piston linked to a normal cylinder. When activate the corrispondent slider, the cylinder seems to multiply.Is that possible in the current version?
                                            http://www.youtube.com/watch?v=vNlhGt32oBg&eurl=http://sketchuptips.blogspot.com/2008/09/sketchyphysics-3-preview-video.html&feature=player_embedded
                                            • 3 / 5
