    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 224.0k Views 79 Watching
    • Jean-FrancoJ
      Jean-Franco
      Yes ! now it works !
      thank you.
      Jean-Franco
        Works! 🎉
          remus
          Works like a charm, thanks very much 👍
          • Jean-FrancoJ
            Jean-Franco
            in scene3 we have this at the end for the smallest surface.
            Jean-Franco
            • W
              wikii
              Seems last at the end are false! 😉
              You can add a hori line at the end of curve to avoid it.
                Not a big deal than you can erase it but... perfection is needed 😒
                • Jean-FrancoJ
                  Jean-Franco
                  I do not understand exactly the difference between the two first scenes.
                  See below the top view when I selelect parallel projection.
                  Jean-Franco
                    Yes but it is some tedious 😉
                    Beauty is go to the end ☀
                    The curious thing is all seems good till the previous module ❗
                    • W
                      wikii
                      [attachment=0:14ocmtqc]<!-- ia0 -->FAK_test_scene1.jpg<!-- ia0 -->[/attachment:14ocmtqc]
                      In the second scene,there is a construction point at start of the curve.
                      • Jean-FrancoJ
                        Jean-Franco
                        Now I got it !
                        But was not easy to understand or to see your construction point because of the line style you used.
                        Thank you.
                        Jean-Franco
                        • E
                          Ecuadorian
                          Wow, thank you wikii...
                          So many responses in so little time... This just shows how much we needed this.
                          -Miguel Lescano
                          • MALAISEM
                            MALAISE
                            Thank you wikii sooo fast : incredible 👍
                            MALAISE
                            • E
                              Ecuadorian
                              Actually, it would be really cool to also have a script that orients the profile just like that final face... It could be called "FollowMe Slide", as it would not keep the profile vertical, but instead place it perpendicular to the curve, like in Playground slides, or toboggans.
                              -Miguel Lescano
                                dtrarch
                                Wiki Thank you Thank you 😍
                                WOW this is the real missing link in SU fixed at last.
                                This worked perfect right out of the box.
                                For Architects developing roadways on non level topography this is a must have tool and for the handrail up sweeping stairs this will be a life saver.
                                I have begged, offered bribes, and even bathed every day to hopefully have someone put this together with no luck until the Wizard of Code delivered.
                                An icon would be a helpful addition if not too troubling to add.
                                Just brilliant and generous.
                                Thanks more than I can properly express.
                                dtr Architect
                                PERFECT.png[/attachment]
                                • W
                                  wikii
                                  So we must make that 😉
                                  Works but curious method 💚
                                  0.02 provide perfect ending and autosmooth.
                                  • E
                                    Ecuadorian
                                    This should have been a tool in SU from the very beginning, thank you wikii!
                                    -Miguel Lescano
                                      So we must make that 😉 (a vertical is more easy to draw in the space)
                                      (bending effect on the right on the smooth view is just perspective !)
                                      Another thing : measure of lengh of the "rectangle facet" must be less than the radius of the curve else auto intersections become! 😉
                                        0.02 is the version, I had believed that was a parameter 😄
                                        But sorry seems you have uploaded a false version! I have always the same result and not your result !
                                        • W
                                          wikii
                                          I have uploaded a wrong package.
                                          Sorry for that,please download v0.02 again.
                                          • X
                                            xrok1
                                            an option for the sweep to start at the beginning of the line no matter where the profile is drawn would make this perfect. maybe a checkbox for start at path or start at profile. then maybe a normal(size of path) or distance from(size*distance from path) instead of the construction point. it seems a pain to make a construction point?
                                            • 11
                                            • 12
                                            • 2 / 12
