    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 220.5k Views 79 Watching
      remus
      not sure if im doing something wrong but i cant see it in the plugins menu...
        Terrible!!! 😎
        PS Is it only for pro version? Because I see nothing on the Plugins menus free V6, V7 😮
          sepo
          Tried on the other comp... same thing.
          • W
            wikii
            open fak.skp,
            follow the text in the each page.
            • Jean-FrancoJ
              Jean-Franco
              could you help me ?
              I don't see any FAK command in the plugins menu after extracting the FAK.rbs file in my Plugins directory.
              Jean-Franco
                sepo
                It does not show in plugins.
                  remus
                  Wikii, if its any use this is what i get when i try and load it from the ruby console:
                  load "FAK.rbs"
                  Error; #<SyntaxError; (eval);131;in `load'; C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                  RBS1.0
                  C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; syntax error
                  RBS1.0
                  C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; Invalid char `\030' in expression>
                  (eval);131
                  • W
                    wikii
                    Sorry , I did't test it without Sutool.
                    I have posted the fixed version,please download it again.
                    • Jean-FrancoJ
                      Jean-Franco
                      Yes ! now it works !
                      thank you.
                      Jean-Franco
                        Works! 🎉
                          remus
                          Works like a charm, thanks very much 👍
                          • Jean-FrancoJ
                            Jean-Franco
                            in scene3 we have this at the end for the smallest surface.
                            Jean-Franco
                            • W
                              wikii
                              Seems last at the end are false! 😉
                              You can add a hori line at the end of curve to avoid it.
                                Not a big deal than you can erase it but... perfection is needed 😒
                                • Jean-FrancoJ
                                  Jean-Franco
                                  I do not understand exactly the difference between the two first scenes.
                                  See below the top view when I selelect parallel projection.
                                  Jean-Franco
                                    Yes but it is some tedious 😉
                                    Beauty is go to the end ☀
                                    The curious thing is all seems good till the previous module ❗
                                    • W
                                      wikii
                                      [attachment=0:14ocmtqc]<!-- ia0 -->FAK_test_scene1.jpg<!-- ia0 -->[/attachment:14ocmtqc]
                                      In the second scene,there is a construction point at start of the curve.
                                      • Jean-FrancoJ
                                        Jean-Franco
                                        Now I got it !
                                        But was not easy to understand or to see your construction point because of the line style you used.
                                        Thank you.
                                        Jean-Franco
                                        • E
                                          Ecuadorian
                                          Wow, thank you wikii...
                                          So many responses in so little time... This just shows how much we needed this.
                                          -Miguel Lescano
                                          • MALAISEM
                                            MALAISE
                                            Thank you wikii sooo fast : incredible 👍
                                            MALAISE
                                            • 11
                                            • 12
                                            • 1 / 12
