    Greeble Beta (Updated Feb-06-2009)
    69 Posts 15 Posters 10.3k Views 15 Watching
    • Chris FullmerC Offline
      Yikes, I do not fluently read ternary expressions then. I can see sort of what its doing, but there's a lot in there I don't get. Maybe in time 😄 Also Rick, I am getting this error:
      Error; #<ArgumentError; Cannot create unit vector from zero length vector>
      C;/Program Files/Google/Google SketchUp 7/Plugins/offset.rb;49;in `parallel?'
      C;/Program Files/Google/Google SketchUp 7/Plugins/offset.rb;49;in `offset'
      C;/Program Files/Google/Google SketchUp 7/Plugins/offset.rb;39;in `upto'
      C;/Program Files/Google/Google SketchUp 7/Plugins/offset.rb;39;in `offset'
      C;/Program Files/Google/Google SketchUp 7/Plugins/clf_greeble.rb;159;in `greeble'
      C;/Program Files/Google/Google SketchUp 7/Plugins/clf_greeble.rb;137;in `each'
      C;/Program Files/Google/Google SketchUp 7/Plugins/clf_greeble.rb;137;in `greeble'
      C;/Program Files/Google/Google SketchUp 7/Plugins/clf_greeble.rb;200
      C;/Program Files/Google/Google SketchUp 7/Plugins/clf_greeble.rb;200;in `call'
      I'm sure its because I'm passing bad geometry to your offset script. What do I need to check so as to not pass bad geometry to offset.rb? Thanks!
        Seems works fine 6 & 7 😉
        Even for the "Tin" ☀
        Bravo! 😎
        XP on PC 😉
          Jim
          @rickw said:
          I use this:
          (Sketchup.version[0,1].to_i<7) ? (view.model.start_operation "name here") ; (view.model.start_operation "name here", true)
          What happens when SketchUp reaches version 10? 😆
            todd burch
            @jim said:
            @rickw said:
            I use this:
            Rick will have to learn a new parsing technique! 🤣
              RickW
              Haha! Good point. But Google's backwards-compatibility policy is for 3 versions. By that time, there will be no more need for the "true" flag so it will cease to exist after version 9, and then I'm safe until SketchUp 70.0. At that point, my crystal ball gets a bit fuzzy.
              But just in case I'm wrong, this is better:
              Sketchup.version.split(".")[0].to_i<7
              RickW
              www.smustard.com
                RickW
                Can you email me a sample .skp file that's causing the error?
                RickW
                www.smustard.com
                  tomot
                  I had the exact same error on one of my files. when I quit SU7. I was asked if I want to fix the error in that file. Which I did. Since then I don't get that error anymore.
                  FYI: new SU7 install under Vista64, the only installed plugins are what the greeble script requires.
                  my plugins
                  tomot
                    RickW
                    Do you mean that offset.rb is installed with SU7?
                    RickW
                    www.smustard.com
                      tomot
                      Yes, offset.rb is installed with SU7
                      However my previous post and attached picture still confirms the same greeble problem when used with SU6 operating under Vista64. Mind you there are a significant number of Plugins that maybe contributing to the problem, BTW compospraytool.rb is not installed in that plugins dir.
                      my plugins
                      tomot
                        Bummer, there must be another script that is interefering too then. I'm wondering, do you have makefaces installed on the version 6? If not, could you install it and try it? It also uses progressbar.rb. So it should be broken too.
                        I might just have to releae a version that does not use progressbar I guess.
                          Your version is always written 0.25
                          you don't increase number between version?
                            😄 I've been updating it, but I tihnk I forgot to on this last update because it was a small update. I tihnk it went up to .0255 I do have .027 ready. It fixes a bug that makes the script stop after you greeble the same geometry a few times. But I fixed that and found there is still another problem that does the same thing. So I'm hoping RickW can shed some light as to how to fix the problem. Then other scripts are messing with progressbar too and causing me grief. So maybe today or tonight I'll do a big update that fixes lots of these little things.
                            Thanks for the reminder on the version number. i'll make sure I keep it up to date from now on 😄
                              todd burch
                              I am confident progressbar.rb is not broken. It gets used 1000's of times a day.
                              I remember putting in a diagnostic one time to trap a bad call to a method with a nil value. I overrode the nil class to see who was calling it. Found the error in no time flat.
                                I agree 100% Todd. Progressbar is not broken. Its been around forever. Tomot PM'ed me and found that he does in fact have the component spray tool installed. That is the ruby causing the problem on my end. I even posted to the Spray tool thread stating that I think its causing issues with progressbar. But no response from Didier yet. I'll test it out on these school computers that have no plugins installed. I'll put in my script, progressbar, and compo_spray.rb and see if I get the same error. But in my mind, its already solid. Component spray is interfering somehow.
                                If it is true, how does he go about solving it? Does he maybe have some code that is not wrapped in a module or something? Would that fix it? His script is scrambled so I can't look at it its guts.
                                  RickW
                                  Yes and yes. 😄
                                  RickW
                                  www.smustard.com
                                    todd burch
                                    I think Didier put the progressbar script code in his script, and modified it with a timer, so that if the script was running longer than a certain time, it would interrupt the process and put a dialog in front of the user to continue or note. Great idea. Less than stellar execution. I could extend progressbar with a callback to make this type of functionality general purpose, and then he could just call the one that works! (Ouch).
                                    The benefit of using progressbar.rb, is that when I get around to upgrading progressbar with platform specific code, user's will have a real nice, platform correct progress bar that's not buried on the status bar. I'll make it so that the user could hit CANCEL at any time to interrupt the script.
                                      Todd that all sounds superb! And that makes sense what happened with the sray tools and progressbar.
                                        Vital ☀
                                          RickW
                                          The offset problem comes down to the offset distance being exactly half a face's dimension. This creates a line rather than a face, and things go nuts at that point. Working on a fix for both sides of the issue.
                                          RickW
                                          www.smustard.com
                                            Ahh, that makes sense Rick. I could test that my random offset value does not equal 1/2 the width of height of the square faces - or something along those lines. Thanks for looking at this,
                                            • 3 / 4
