    A website?
    29 Posts 12 Posters 1.9k Views 12 Watching
      reymond
      Hi Ray
      Watch this.
      ist free with advertising links on the site.
      http://www.jimdo.com
      its realy easy to use. πŸ‘
      Sketchup & Vray Trainer
        todd burch
        Your fonts are too fat, and it takes WAY too long to load. Other than that, it's OK!!
          Double Espresso
          Ray,
          My advice is keep it simple. People are coming to your site to see your car designs not how fancy the site design is.
          Essentially... my name is Ray... this is what I do... these are my cars.
          Right now it takes way too long to access the designs, perhaps more folders with less cars in each.
          I think you are close to a great site that shows off your talent... good luck.
          • RayOchoaR Offline
            RayOchoa
            http://ray-ochoa.webs.com
            Edit dammit i had to change again i hope yall don't mind.
            CaR DeSiGnS bY mE
            http://ray-ochoa.com
            • RayOchoaR Offline
              RayOchoa
              okay i changed it. i will make it simpler.
              CaR DeSiGnS bY mE
              • RayOchoaR Offline
                RayOchoa
                okay i changed it. i will make it simpler. i edited the post before this one
                CaR DeSiGnS bY mE
                • RayOchoaR Offline
                  RayOchoa
                  CRAP okay i changed my website from cardesign-rayochoa.com to ray-ochoa.webs.com LESS TO WRITE 😳
                  CaR DeSiGnS bY mE
                    Ray, just an advice on images. If you upload an image to be displayed in a certain size, the html code can display a bigger image smaller than the "real" image is but it's a waste of bandwidth as well as loading time. So if the images are displayed in 328x295 but the file is 800x552 (which is the case with your website), it will take to load as long as if it were displayed in the original (880x552) size but you can only see the "smaller" version.
                    So if you do that, resize your images to smaller and upload them that way instead (or link to the bigger version somewhere). Loading time will multiply.
                    • RayOchoaR Offline
                      RayOchoa
                      you mean for the album?
                      CaR DeSiGnS bY mE
                        No. for the Homepage. I wouldn't even have looked if it hadn't ben suspicious for loading too slow. Go to Properties in the context menu for the image (see attached - in Hungarian)
                        • RayOchoaR Offline
                          RayOchoa
                          I put a direct link from photobucket. i changed it to this one green car. idk if its better though, all the computers i go to my site with have fast connection
                          CaR DeSiGnS bY mE
                            todd burch
                            I seem to have issues when people link to photobucket. Long load times, even for small images, and may times, images fail to load altogether. Maybe it's just Safari.
                              I have many issues with such image sharing sites as well (Imageshck being even worse). Sometimes I don't even click on a posted thumbnail in the Gallery because my driving license expires by the time it loads. πŸ˜•
                              • Alan FraserA Offline
                                Alan Fraser
                                The image still takea while to load...better, but still draggy. If you're having a slot that's 214x428 then that's the size the image ought to be. Your 400x800 pics are taking almost 4 times longer to load than necessary (twice the size in both directions).
                                I too don't like Photobucket or Imageshack. It's also the case that sourcing your images from there means you are dependent on them...if they're down, your site is useless, even if it's having no problem with the actual hosting. If it's possible to stick all your images into an images folder...maybe keeping the general site graphics and gallery images separate...I'd do that instead.
                                3D Figures
                                • sketch3d.deS Offline
                                  sketch3d.de
                                  domains & hosting is cheap, ray-ochoa.com is (still) free:
                                  Access Denied
                                  (www.godaddy.com)
                                  for generating content, get a WebCMS, e.g.:
                                  http://www.wordpress.com/
                                  http://www.joomla.org/
                                  tons of free and commercial templates avail.
                                  have fun,
                                  Norbert
                                  • 2 / 2
