    Groupbytextures.rb
    10 Posts 3 Posters 777 Views 3 Watching
    • BurkhardB Offline
      Burkhard
      seems it does not work on V7
      Any ideas Rick?
      greets Burkhard
      http://www.ia-plus.de
        RickW
        For some reason (which I will try to figure out later), G/Cs are not exploding as expected. If you run it a few times (# of times to run = # of levels of nested groups), it will eventually get everything grouped correctly.
        RickW
        www.smustard.com
        • BurkhardB Offline
          Burkhard
          Thanks Rick, it is quit useful for me when I'm working with a 3d firm who wants to have the model in groups for every texture. Seems a lot easier for them to make a finish.
          If I run the script the groups and components explode all as expected but they do not regroup by materials. That's why I asked if it works in V7.
          ( For exploding I can use the bomb.rb but for grouping by materials I need the script )
          Burkhard
            mirjman
            could this be because the material is applied to the group and not at the face level?
            • BurkhardB Offline
              Burkhard
              No, I tried it with simple boxes and just one face on every box. Can you confirm this or does it work for you?
                mirjman
                i can't seem to replicate this, can you tell me what you are doing to cause the problem
                  RickW
                  Strange. I tried it, and it grouped everything without a problem. Please try running the script while the the Ruby Console (Window>Ruby console) is open, and see if any error messages appear. If so, copy and paste them here and I will see what is happening.
                  Or if you can email me the model, I will look at it.
                  Thanks,
                  RickW
                  www.smustard.com
                  • BurkhardB Offline
                    Burkhard
                    This is what comes out:
                      RickW
                      Just a guess - try purging unused materials, and see if that fixes the problem. If so, then I have an easy fix. 😄
                      RickW
                      www.smustard.com
                      • BurkhardB Offline
                        Burkhard
                        You're right, now it works. But I have to delete Sanchi (?) as well. With him it doesn't work.
