    [Req] Texture Corrector.... PLEASE
    40 Posts 10 Posters 13.7k Views 10 Watching
      davide.skp
      beautiful bill! excellent work!
      I tested your code ... work work work ... so I am very happy ...
      I have done tests with the attachment of free agent: texture to fix- and with some of my models of plants and point out these problems:
      1] Unfortunately, the code works perfectly from the face below the one above [ent.material = ent.back_material]
      2] I proceeded to change the code, of course, follow your footsteps,
      "get_back_UVQ to get_front_UVQ
      ent.material = ent.back_material to ent.back_material = ent.material "the ruby turns ... no errors but no results ... boh!
      3] also on some files (small) I go in BUG Splat!
      attack:
      1] ruby with changes according to your advice
      2] bill's ruby
      3] some SKP trees
      [1] ruby with changes according to your advice](/uploads/imported_attachments/n75v_BILLW_011.rb)
      [2] bill's ruby](/uploads/imported_attachments/1FRl_BILLW_010.rb)
        I did notice that if the faces have only tree points the ruby doesn't handle that. But I've not experienced any bugsplats.
        I did run into bugsplat when I tried to transfer material from a face that didn't have an material applied. Solved that by adding a check.
        Just to make sure David, the problem you're experiencing is that you can transfer from back to front, but not from front to back? And some times you get bug plats? Does this happen with Bill's code or with mine? Both?
        Does that faces have less then four corners?
          davide.skp
          TomTom, the bug come only with BILLW_010.rb.
          I test your ... don't splat but don't work
          can you test with my plant? ๐Ÿ˜Ž
          CIAO!!!
          [3] some SKP trees](/uploads/imported_attachments/z05o_vivaio.zip)
            Didn't seem to have any problems. Attached is your model with the result.
            vivaio.zip
            Did you click on "Frontface to Backface" or "Backface to Frontface"?
              davide.skp
              sorry sorry sorry ... probably I click bkface to front ...
              now work ....
              ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
              i'm very happy
                ๐Ÿ‘
                • N
                  numerobis
                  WOW! VERY cool plug! Thank You so much! i have to import a lot of trees into sketchup these days - without this nice tool it would be nearly impossible to get the textures right! ๐Ÿ‘
                  one question: would it be possible to write a ruby that can center a texture to the face it has been applied - some of the trees i import have many of their leaf textures not centered on both sides... any idea how this could be fixed โ“
                    Can you post a screenshot? And what trees is it? XFrog?
                    • free agentF
                      free agent
                      ooo that would be quite interesting, not just centering but conforming to the quad it is applied to, like a square texture image will stretch itself to fit a retangle face, that would help for remapping leaf textures in sketchup, althought sketchups new export to photoshop option kinda does that already, it should have extra handy uses... is that possible, that would be an awesome plugin
                      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                      • N
                        numerobis
                        sorry for the delay...
                        the trees are xfrog - but i have problems with decentered textures with other models too...
                        i've done some testing with the xfrog trees - there is a difference if i apply the "front to back" tool to the component (containing all leaves) or open the component to select all faces
                        to correct the textures...
                        at the moment i open the the component all textures get messed up forever. no way to restore the original coordinates.
                        correcting the coordinates of the component works! but if i open it after correcting... ๐Ÿ˜ฎ no way to go back - only reloading the file can fix it
                        here's an example:
                        http://img34.picoodle.com/img/img34/3/2/2/f_beforeafterm_6e83bf5.jpg
                        would it be possible to write a ruby that centers and resizes the textures?
                        i was really hoping for better texturing tools in v7...
                        ...and for high poly + x64 + multi core support...
                        ๐Ÿ˜ข
                        • 2 / 2
