    A simple scene
    33 Posts 14 Posters 2.9k Views 14 Watching
    • N Offline
      nomeradona
      hehehe this is funny, i thought that this model was from a vietnamese guy, and when i browse this forum, man there were a lot of rendered here already. anyhow i think i should recorrect and reedit my posting by giving a worhty thanks to pibuz. slight alterations were also done.
      to the mods. is it possible to merge this with the indigo interior scene. my apology...
      • N Offline
        nomeradona
        ok last one from me here
        http://i334.photobucket.com/albums/m421/nomeradona_1234/finaltestnomer-1.jpg
        http://i334.photobucket.com/albums/m421/nomeradona_1234/closeup-2.jpg
        http://i334.photobucket.com/albums/m421/nomeradona_1234/dof.jpg
        • soloS Offline
          Awesome work Nomer!!
            sepo
            Yes, I would agree....very subtle.
            • FrederikF Offline
              Frederik
              AWESOME, Normer...!!! 👍
              Could easily fool me to believe these were actual photoes... 😉
              Cheers
              Kim Frederik
              • axeonaliasA Offline
                axeonalias
                Wow last shot is amazing,great stuff!
                https://sketchfab.com/Axeonalias
                • StinkieS Offline
                  Stinkie
                  Good work. The shadows those bowls cast look too well-defined to me, though. Obviously I could be wrong. 😄
                  • N Offline
                    nomeradona
                    thanks pete.. btw i watch before your video at basecamp now atleast know you with that. are you left handed?
                    • N Offline
                      nomeradona
                      thanks sepo...
                      • N Offline
                        nomeradona
                        thanks for the compliment frederick
                        • N Offline
                          nomeradona
                          thanks axeonalias.. im happy also with that one. except the shadow.
                          • N Offline
                            nomeradona
                            actually you are right stinkie. i will explain the workflow. its a kind off choosing between egg and chicken.
                            see vray doesnot support IES photometric. in order to have the ies effect, there is a workflow introduced by andeciulala using opacity map. this opacity map will be place on the receptacle and just like a gobo map will cast the light with an ies effect. but the problem of course you can do that if you are using soft shadow. soft shadow wont show the effect. on the last image that you are using the radius is actuially "0" therefore there would be no softshadow. so the casting of shadow is really sharp. of course i could edit in photoshop. nevertheless.. sharp eyes you have there....
                              archkiranjith
                              awsome work dude!!how do u get that blurred effect in the last image..or is it photoshop edited?..
                              • N Offline
                                nomeradona
                                its dof in vray su. but i was not satisfied completely because some of the blurriness did not occur that much at front (foreground) so i cheated a bit in ps by blurring the front area.. sssshhhh! 😉
                                • N Offline
                                  nomeradona
                                  this one rendered in hypershot.. 42 minutes with a very high rendering settings
                                  http://i334.photobucket.com/albums/m421/nomeradona_1234/hypershot.jpg
                                    kwistenbiebel
                                    Hypershot isn't really leveling Vray quality yet, but it is a nice and speedy (but expensive) tool. Hypershot is a bit more difficult to control for interiors but you seem to make it work.
                                    Your Vray renders are super Nomer! Perfect balanced light and that soft touch really is becoming your trademark.
                                    I particularly like the close-up on the bowls.
                                    The DOF in that image is exciting. Did you use a camera generated DOF or the Depth Map option?
                                    • N Offline
                                      nomeradona
                                      i agree with that, getting the hand of it though.. the light source aside from hdri still not comparing with vray though. although it has emissive lighting using hdr, still have difficulty to catch up with other engines when it comes to architectural vizualisation. but im trying to push its limit in archviz and i think i had some good success to it. one thing if you really need to concentrate on this, a thorough knowledge of doing your own HDRI images is a must. like for example on the previous example i cant seem make the light to go down a bit so that the shadows and light of the shutter will appear. of course one way of doing it is rotating the whole model. but its a kinda doing lot of hassle.
                                      as for the vray dof. i actually check the camera DOF in vray, but i still have to do some cheat in PS, by blurrying some of the areas.
                                      one thing i dont like is still the facted reflection of the bowls, you cant cheat vray, it wont recognize the smoothing done in sketchup. of course using subdivide will solve the problem, or modellin with high facets for those models near the camera.
                                      • N Offline
                                        nomeradona
                                        another hypershot render. this time i have added a backplate and improved my bump on the wall by increasing the scale and making the bump higher. soft light effect added in Photoshop using diffuse glow filter and adjusting the curve.
                                        http://i334.photobucket.com/albums/m421/nomeradona_1234/Hypershotfinal.jpg
                                          sepo
                                          Nice but seems Hypershot does not produce any occlussion. That is quite obvious arround shelves, especially if you compare it to your Vray renders.
                                          • MALAISEM Offline
                                            MALAISE
                                            great!
                                            let's say us how long it takes for calculation .
                                            MALAISE
