    Coloured Triangular Flashes
    7 Posts 4 Posters 402 Views 4 Watching
      SuperMario
      ๐Ÿ˜ž
      Hello Folks,
      Quite often I get triangular flashes of colour, strange shapes, etc. that force me to move back and find some angle that moves them out of sight.
      Can you tell me what causes them, what I may be doing wrong, etc ?
      Mario
        remus
        It sounds like it might be a z fighting issue.
        basically it happens when you have 2 faces sharing the same space in SU. you can easily select one of the faces and delete it. This should sort it out (if z fighting is the issue.)
          Hi Mario,
          I am pretty sure that this is the so called "Z fighting" which menas that there are more than one coplanar faces in the same place (imagine two groups on top of each other) where SU cannot decide which face to display and therefore they "fight" for visibility.
          You should always avoid such situations by deleting either of the two faces. See a file attached with an intentional example (orbit a bit around).
          Z-Fight.skp
          Remus: don't you have exams to prepare? ๐Ÿ‘ฟ
            remus
            Finished those last week, although i have got quality television to watch...
              ๐Ÿคฃ
              • AnssiA Offline
                Anssi
                Strange distortions like circles looking like cut potatoes, accompanied with strange clipping and triangles jutting out of objects are also the standard symptoms of too large model extents (either the model is too far from the SU origin or the model has parts (stray lines from a CAD import are enough) that are located somewhere beyond the horizon.
                Anssi
                  SuperMario
                  Thank you Gaieus, Remus and Anssi,
                  It's surely the co-planar surface problem (Z fighting) since I remember re-drawing the same surfaces somewhere. Will re-examine the drawing and find out.
                  Thanks a lot
                  Bye
                  Mario
