    Turning Wood Grain
    4 Posts 3 Posters 472 Views 3 Watching
      swall
      Can you turn materials like wood grains to use while drawing raised panel doors?
        swall
        How can you turn materials at diffrent angles
        I am drawing Rasied Panel Doors and when you apply a wood grain on the style of the door it is ok but when you apply it to the rail the grain is going in the wrong direction.
        • V Offline
          Voder Vocoder
          Read about the Position Texture tool in the User's Guide.
          ~Voder
            ~Voder
            Here:
            http://download.sketchup.com/sketchuphelp/gsu6_win/Content/D-Modification_Tools/ModTool-PositionTexture.htm
            1. right click the face (with the material in the wrong direction)
            2. go to Texture > Position
            3. Right click again and go to > Rotate... > choose the angle (I gues 90 degrees)
              Note that positioning a texture can only be performed on a single face; not on curved surfaces nor on groups/components (unless you turn on hidden geometry with surfaces or edit the groups/components).
            p.s. I merged your two posts (the one in the CMS forum with this one) about the same issue.
