    Plug Ins
    12 Posts 3 Posters 877 Views 3 Watching
    • Chris FullmerC
      Hi Skinman, each plugin can choose where to install itself. They don't all go into the plugins menu. The plugins menu will only appear after you have installed a plugin that is set to install itself to that menu. So if you installed makefeaces.rb, it actually ends up in the Tools menu. drop.rb ends up in the right click menu, and not in the regular menus.
      So dig around and you'll probably find what your looking for in another menu. If you cant find it still, let us know what plugin it is and we'll help you.
        skinman
        the pluin is: Weld 3.0, file name: weld.rb
        I still cannot locate the single plug-in tool or any sort of indication of a menu where it may be.
        • GaieusG
          Well, weld goes to the Plugin menu - so where did you install it?
            skinman
            Plug-in Folder inside of Sketchup Application
            • GaieusG
              Here?
              Macintosh HD/Library/Application Support/Google Sketchup 7/SketchUp/Plugins
                skinman
                Ah. I had it in Macintosh HD/Applications/Google Sketchup 7/SketchUp/Plugins
                Should that do it?
                • GaieusG
                  Try the above (note I'm on PC so never trust me πŸ˜‰ )
                    skinman
                    Awesome. It worked. Thank you much.
                      skinman
                      Another Question if you have time. I imported a DWG into sketchup. A bunch of contour lines. it came into sketchup as segmented individual lines rather than composed lines. Any idea how to avoid this? Hence my need for the weld plugin.
                      • GaieusG
                        You got the answer in the other topic you started about this. πŸ˜‰
