    Faces/planes
    28 Posts 4 Posters 5.0k Views 4 Watching
      soco
      The Axes highlighting tool helps too... I realise I'm not drawing what I mean to draw much of the time! I've got the go-ahead to post a model, can I attach it to a post? If so, what's the best format?
      • GaieusG
        I'd go for skp. 😄
        Under the text area you are posting, there's the attachment tab.
          soco
          Thanks, I see it now, cunningly concealed:)
          Here is my masterpiece/mess so far then...
          SU_model_130109.skp
          • GaieusG
            Wow, this is a realmess (if you don't mind me saying that).
            • raw geometry scattered all over on different layers
            • non-planar geometry intersecting each other all over the place
            • groups with illogical (or at least un-understandably misaligned) axes
            • lots of Z fighting (showing faces on top of each other)
            • have you seen hidden geometry on? (View menu)
            Did you inherit the whole layer system from the CAD drawing? (Do you really need them?)
            To really tell the truth,I'd definitely start over. I am really sorry to tell this but I'm pretty sure that with a better approach,you could get it quite right much sooner than cleaning this model up.
              soco
              Don't worry, that's exactly what I was expecting. I'm very methodical usually, believe it or not, but since it was a first attempt I thought I'd throw caution to the wind (and hopefully learn from my mistakes!) Probably not the best building to start on, what with the irregularities. I will start afresh tho. Thanks for you help!
              PS Can I remove the attachment now that I've embarrassed myself?
              • GaieusG
                IMO the best would be to bring in the siteplan but
                • make sure to "flatten" it in cad before.
                • Then try to get rid of the layers (delete them moving everything onto the default layer).
                • Then explode everything down to raw geometry.
                • Then erase every unwanted bits (the arc symbols for door openings and such...)
                • and now with a relatively clean model, start over but make sure you have all the floor plan of the double walls and all that are supposed to be connected pare connected etc.)
                • and only psuh/pull it up when you are already done with this.
                • those fancy roofs should be the last things to model.
                  soco
                  Okay, thanks for the pointers... onwards and upwards!
                    soco
                    Good morning!
                    Having further cleaned up my CAD floorplan and started my model again things are going much better. Mostly I can generate faces by tracing one side of a shape in the imported, exploded floorplan, which is a revelation! However it happens quite frequently that I cannot generate a face and this seems to be because one or more of the points involved has a Z co-ordinate of approximately(indicated by squiggley line)0 instead of 0. Is this another messy CAD issue? I draw in 2D only in CAD so assumed all lines in a plan would have the same 'Z' co-ordinate (ie. none at all). Is there some way of establishing a groundplane in SU with a fixed Z co-ordinate and 'gluing' the imported floorplan to it?
                    • GaieusG
                      Hi and good morning (it's already afternoon here 😄 )
                      There are several ways to "flatten" a sloppy CAD import (although flattening it still in CAD seems to be the safest way prior to import).
                      Anywy, there is a $ 10 plugin "Flatten.rb" at Smustard which can do that. If you are planning to use many CAD imports, it's well worth (just think about the time you have alreadyinvested in this particular problem). There are also other scripts there that help with sloppy CAD files.
                      Then you can always draw a big face under the imported linework and using the Drape tool of the Sandbox, simply "project and intersect" your lines onto that - obviously co-planar - face.
                      A third, quick,manual method (onlyif you have few faulty endpoints) is to move the vertices to 0 Z height. Deselect everything and hover over the culprit endpoint with the move tool. When you get the "Endpoint" inference, click on it, press the Up or Down key (to lock the move on the Z axis) and move it down to zero by inferencing to a known, good point.
                      With this latter method, you can often quickly fix some minor problems of lines/vertices out of alignment in other cases, too.
                        soco
                        I just used the Drape method (discovering Sandbow tools in the process)and it's worked perfectly.
                        Thanks a million!
                        • GaieusG
                          Great! 👍
                          Please, come back when you get to the next phases.
                            soco
                            Well just when you thought it was safe to come out, I'm back! It looks as if I spoke too soon...
                            About 30% of my groundplan endpoints ended up with a Z-coord of 0.05, while the rest are at 0.00. I have doublechecked my groundplane mesh, which has all corners at Z-coord 0, and re-Draped, but the renegade endpoints won't shift. I completely exploded the CAD groundplan before export. In order to Drape it on the groundplane mesh I had to make it into a SU group (as I can only select one entity to drape) - could this be the problem (ie. will elements within a group drape properly)?
                            • GaieusG
                              Yes, groups should drape properly. Try to move your plan a bit above the face you are draping on. The drape tool should "project" all the lines smoothly.
                                soco
                                I did that and re-Draped... I lost a few lines but those that did reappear were all on the correct plane. Redrawing a few lines is a tiny price to pay for having nice clean plan to extrude from!
                                Thanks, again.
                                  soco
                                  Hello again,
                                  Progress is good with the new model! I'm nearly ready to start roofing and was wondering: do you have any tips?
                                  I have the pitch of each roof plane, its starting(lowest)level and its plan dimensions, but not the exact heights of all the supporting walls. I have extruded those walls to the datum of the lowest point of the corresponding roof plane.
                                  What is the best way to bring the (level)top face of walls up to meet a pitched roof undercroft?
                                  If I draw a roofplane so that it projects over the external walls is there an easy way to trim back projections where necessary (using an intersecting face, for example)?
                                  • GaieusG
                                    Yes,intersecting will be your best friend here.
                                    First of all, make a group of what you have now (especially the walls) so that when working on the roof, you won't affect them.
                                    Now enter the wall group and copy the very top face (which is "covering" the wall) with a simple Ctrl+C after selecting it.
                                    Then exit the group, go to Edit > Paste into place; it will be placed to the same location and you can work on it so that it can be part of your roof and the roof line will perfectly match the walls.
                                    You can even hide the walls now...
                                      soco
                                      Hello,
                                      I think I've got the hang of SU basics now, mainly thanks to the help I got here!
                                      I'd like to put the model in its landscape context:
                                      Should I start a new model of the landscape, building up the contours etc, and then import the building model into that file? or should I draw the whole thing in one file?
                                      Do you have any tips on the best way to build up landscape? I think I can use the Drape tool to soften out contour edges I have drawn... can I then 'drop' my building into this landscape?
                                      • GaieusG
                                        Either way is just fine (especially with a "not-too-complex" model).
                                        It depends what kind of "input" yoou have;
                                        • contour lines
                                        • you want to work from "scratch"
                                        • point cloud
                                        • you can even import a Google Earth Terrain
                                        • etc.
                                        Well, I don't exactly understand what you mean here but the Drape tool is for something different; for "drawing" contour lines of buildings, roads etc. onto a softened surface (i.e. terrain/landscape).
                                        That would be the Stamp tool (of the Sandbox).
                                        • K
                                          kwistenbiebel
                                          Make that 200 lines.
                                          Rubbish!
                                          • K
                                            kwistenbiebel
                                            The drape Tool sucks big time for projecting lines on a surface.
                                            It only works when you have less than app. 1000 lines.
                                            Anything higher?: Crash guaranteed!
                                            I need this urgently in a project and I am really swearing. Damn Sketchup. 😡
