    What have I done wrong
    20 Posts 6 Posters 3.6k Views 6 Watching
    • GaieusG
      Hi Newbuyer,
      I cannot see those irregularities. They would look like "z-fighting" in your image (when there are two faces on the same plane "fighting" for visibility) but that's not the case in your model.
      There were a few back faces and missing faces though - I've cleaned up the model a bit now.
      door2.skp
      • N
        newbuyer17
        Thanks. That looks great. Could you not see what I meant initially from the jpg captures?
        Either way, it looks really clean now, but I'm struggling to work out/comprehend what you did?
        I actually thought I was getting somewhere myself, in that I drew a line across the top and pulled it down, and I got a flat surface across the top of most of the model. Deleting that surface sort of allowed me to do what I wanted to do, but it looks nowhere near as neat as it does now.
        Thanks a lot for tidying that up though. It looks much much better. If you are able to explain (in idiot's terms) to me what you did that would be even better, but I admit I'm starting to get a bit lost in termanology.
        • GaieusG
          Okay, let's see.
          First of all I got rid of profile lines (although they may be of some help with beginners), endpoints and extensions in the Window >Styles > In model > Edit > Edge settings. Now the whole thing looks a bit less jagged already.
          Then I healed some missing faces around what I guess is supposed to be the staircase. Also, I deleted extra lines that you probably used for creating the "fills" and such above doors etc.
          Then I reversed all back (blue) faces.
          I waqs actually not going to do this to make the job instead of you but only to investigate if there was some major problems (most of which would turn around during such a cleanup) but then I found none and didn't want to revert what I'd done already. 😉
          As for the door openings and their tops; I'd've started differently in general, just with the windows. Build all the walls around and only cut all the openings (windows and doors) at the end. But certainly the result is all the same. And I'm not an architect myself either 😄
          • N
            newbuyer17
            Thanks. I'll have a look at what you have said tomorrow when I have my other PC booted up.
            I understand what you say about putting doors and windows in last. The reason I did them at this stage is I need both 2D plans and 3D models of the house. I produced the 2D models showing where the doors were, saved/copied it, then pulled the walls up on the original for the 3D model. If I had left it until last I would have had to open up the doors on both the 2D and 3D drawings separately.
            Hope that made sense. This was a dillemma at the time as to whether to do the doors before or after I pulled the walls up. Knowing this, is it still better to leave doors and windows until last?
            Thanks again for your assistance - you have been a great help on this.
            • GaieusG
              SketchUp would be a stupid toy if you couldn't generate 2D floorplan / elevation views from your 3D model. That's what section cuts are for. With a properly placed (somewhere 3-4' above the floor level) section cut you can display all the doors and (most of) the windows while some built in furniture (kitchen for instance) can (or cannot) already be seen.
              So there's no need for double or not consistent work. See (modified) attached.
              Camera > Parallel projection | View > Standard views > Top.
              door2.skp
              • L
                linea
                Newbuyer
                Are you in the UK? I'm guessing you are as you refer to "building regs". A big part of my job is planning applications. You can definately do all the drawing in SU, the level of annotation needed though is a tall order for Layout. It can be done, but if you use a cad program that has a layout function it might be easier. You can import all the views from SU as dwg files. You could try Progecad-Smart it's free. See example.
                • N
                  newbuyer17
                  Hi linea,
                  Yes, I am in the UK. It was only my intention to get outline permission - not to do the second part myself.
                  The only info I found was on this site
                  404 Not Found
                  (www.diydata.com)
                  Hope I'm not breaking any forums rules posting that. I'm hoping that I can do drawings to the same level as the examples on this using sketchup. My plan is to do what I can then get the council to look over them and let me know what further detail is required. I'm hoping it will be enough.
                  If you have any further info on requirements for outline planning permission then I'd be very grateful/interested. Thanks for suggesting that package. I'll no doubt look at it at some point but after doing battle with sketchup for a few days I'm hoping I don't need to learn another new package!
                  Gaieus,
                  Thanks again for your continued input. I'd even seen a tutorial video on that and clean forgot about it! Just so much to learn I can only take so much in.
                  • L
                    linea
                    I'm hoping that I can do drawings ... using sketchup. My plan is to do what I can then get the council to look over them and let me know what further detail is required. I'm hoping it will be enough.
                    Yes that is a good start. You do need to provide them with a location plan though - thisis the ordnance survey street plan of where the property is. The first option would be to buy one as a jpeg from the UK government planning portal for £19.95 or if you want one that you can import as lines in Sketchup, you can buy a dxf version from Blackwells, to get a decent sized area normally costs around £45. Ordnance survey is a rip off! The free option is to really carefully trace over a google earth import in SU or cad and mark on the surrounding house numbers and street names. I have done this a few times, the results have been accepted by planning but it can be more hassle than its worth so I usually buy them.
                    The planning portal is the best resorce for you but if you need any help let me know.
                    http://www.planningportal.gov.uk/england/genpub/en/1115315884635.html
                    http://maps.blackwell.co.uk/lsm/bmo.html
                    • N
                      newbuyer17
                      Thanks again. I have two O/S type location plans of 1:500 and 1:2500 on hard copy. I am fortunate to work for a utilities company with access to GIS data.
                      However, I'm not going to be able to import them into any CAD packages. From that website I was under the impression they were just standalone requirements.
                      Next door is a straight wall so I was just going to measure the distance from our property and draw it onto sketchup to show proximity.
                      I'd appreciate feedback if you think that will work? I know I should run it by the council but thought it easier to draw something for them to look at first, rather than trying to explain all this over the phone. As I said, I'm confident (well hopeful anyway) I can meet the requirements on that other forum with Sketchup.
                      Thanks again to all who have helped me on this - never expected even half as much helpful advice as I've recieved.
                      • L
                        linea
                        Yes always best to draw up something to show the council first and yes it is fine to supply the o.s. map on a different sheet, just mark in red pen where the development is.
                        • GaieusG
                          @newbuyer17 said:
                          ...I am fortunate to work for a utilities company with access to GIS data...
                          You should be able to export dxf content from GIS (at least AFAIK - that's how I have all the siteplan of my home town from the council I currently work for)
                          • N
                            newbuyer17
                            I will make some enquiries. I dont work with the system myself, I just asked someone (who I dont even know) to do me a favour and print them off for me. If I need electronic copies I'll see if I can get them exported.
                            • N
                              newbuyer17
                              Gaieus,
                              Have managed to recreate what you did all except
                              Could you please explain this step to me. Is it a global setting, or are you colouring each individual face?
                                remus
                                In su all faces have front and back faces: if you draw a rectangle you will see one face is blue and the other white. White is the front face, blue is the back face. You can reverse the direction of the face by right clicking it->reverse face.
                                • GaieusG
                                  Or when you have bunch of back faces, you can select them all (Shift + select = toggle selecion, Ctrl + Select = add to selection, Shift + Ctrl + Select = Deselect) then right click on any of the selected faces and do the reverse operation per Remus' method above.
                                  If you have a neatly and cleanly made model and it's not too complex yet, right clicking on a front face and choosing "Orient faces" may work as well since it should turn all back faces to front faces. There are a lot of factors that influence this however and often unwanted results may occur.
