    Need Someone with Solid Modeller
    20 Posts 9 Posters 1.5k Views 9 Watching
    • soloS Offline
      Crap! that rules me out for this one due to political reasons. 💚
        sorgesu
        http://blog.al.com/mhuebner/2008/12/birmingham_artist_mark_carder.html
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
          kwistenbiebel
          Cool!
          As Remus said,
          Moi3D is indeed the kind of modeler you need for that, Rhino 3D's little but powerful brother.
          It is 'Nurbs' based, which is a much more perfect way to 'describe' geometry than a polygon based modeler like sketchup.
          If it really needs to be technical, Solidworks would be the way to go as it basically is an engineering tool.
            sorgesu
            Solo, do you really think the painter had to be a Bush supporter in order to do the job?
            It isn't a stamp of approval,just work.
            It isn't like agreeing to be the official state artist or his Solids modeler once removed
            Susan Sorger
            • soloS Offline
              I was kidding, it's an awesome commission for any artist, for the recognition alone I'd do it for free.
                sorgesu
                Nope, nope. I don't have time to learn this. I just wasted hours trying to fix my SketchUp model in Moi (I exported as a 3Ds, imported to VectorWorks, which I don't really know, I have an NFR copy, and imported at a 1000 to 1 scale and then exported as an igs which I opened in Moi) and well, I got nowhere.
                I don't want to start from scratch and figure out how the heck to do this in Moi,
                So again I ask. any solid modelers out there who want to do this?
                Susan Sorger
                  mateo soletic
                  Pete,
                  Interesting point, that’s the way I lived it , been doing it all my life , but recognition never comes is big chunks , you get breaks, some when you are bone weary, others when you just need to hide for a few minutes , almost invisible, unless one is in Hollywood (probably).
                  One other thing I noticed is that recognition comes sooner to people that charge for their services, the more ridiculous the price the bigger the recognition.
                  Sorry its off topic but it caught my eye.
                  [Concept Illustrations](http://concept-illustrations.com/)
                    That is quasi impossible! 😉
                    SU Models are "Polygons"
                    Moi Models are "Nurbs"! (Inverse Moi --> SU is possible directly 😉
                    The only thing you can do is use this Converter By Michael Gibson but I don't believe that is a big help, depending of your original model!
                    This is a polygon wireframe to 3dm converter. It enables bringing polygon data (OBJ) into MoI to use as construction guides. Download the file Obj23dmWireframe.zip. Unzip it to some folder, and then you can run the Obj23dmWireframe.exe program. It will prompt you for the name of an OBJ file, and after that the name of a 3DM file. It will read all the polygon data from the OBJ file and convert the edges of polygons into line segments, and save those line segments to the 3DM file that you specified. You can then load that 3DM file into MoI and use those line segments to snap on to.
                    http://forums.polyloop.net/imagehosting/1964732fa54df5e8.jpg
                      sorgesu
                      Thanks so much guys. I actually submitted the scale version of my model in 3 different sizes ( this is a prototype) to an online service that has an automated fix it mechanism. They were able to fix 2 of the 3 STL files. The smallest was not fixable in an automated fashion.
                      So I have something for this go round. But because this is just a prototype and he will be refining and adjusting the product going forward, it really makes sense to find someone who works in a solid modeler to begin with.
                      So the call is still open.
                      Thanks again all. I learned a whole heap of new things here again.
                      Susan Sorger
                      • ton baetenT Offline
                        ton baeten
                        Susan,
                        There was a topic on STL files in the forums.
                        That pointed to Cadspan, they still offer a free plugin to create STL-files right out of SU.
                        http://www.cadspan.com/tools.
                        Maybe it is a solution for your problem: the plugin and/or the company itself.
                        I only have little experience with the plugin. I installed it only 10 days ago, because I also want to go to 3D printing right out of SU files in the near future.
                        greetings,
                        Ton
                          sorgesu
                          Thanks Ton, but I did mention Cadspan at the very top. It didn't work at all. I always come to this forum first when I am searching for any information and I found that. I found that the CADspan converter did some very strange things. For instance, my model is identically mirrored from the centre out to the sides and the Cadspan script treated one side very different from the other. I had rounded edges on my model it was handled adequately on one side and very poorly on the other.
                          The export from VectorWorks had nos such problem.
                          Susan Sorger
                            ton baeten
                            Thanks for your info on cadspan.
                            I must have missed you mentioning this plugin earlier.
                            greetings,
                            Ton
                              smartsizer
                              Hi Susan,
                              I do product design using both Sketchup Pro and Alibre Design Expert.
                              Alibre can output STL files as well as many other formats useful for computer aided design and manufacturing. I have drawn lots of small components that were 3D printed into physical models for presentation of designs for bathroom hardware--towel bars, soap dishes, etc. I have sent you an email (from "frdesigns") including some jpgs of the Alibre models.
                              I can give you a quote for the project if you send me some more info.
                              Please contact me if you think I can be of service. Best of luck with your project.
                              Tim
                                sorgesu
                                Hello Gentleman and thank you for your replies.
                                I think an hourly rate will probably be appropriate for this because there has been so very much back an forth on this protype.
                                It would appear that I have something that is printable with this go. So my client is going to see what the ouptut looks like and when he is ready to request the next round of changes he will need one of you to work with. What I have been doing has been really inefficient.
                                I will provide the contact info for each of you to him and he can take it from there. Thanks so much for responding.
                                Susan Sorger
