    Trouble with running cloud v6
    18 Posts 4 Posters 2.2k Views 4 Watching
    • Didier BurD
      Didier Bur
      Can you send the points file plz ?
      DB
        sean
        Thank you for your response...I'm very excited to use this incredible feature you created.
        I ran into the same error message when using the example .dat file, but here is the small data set I'm trying to use.
        1000.00,1000.00,100.00
        1034.533858,993.624808,99.908233
        1020.720428,982.411558,99.907236
        1008.103818,993.279776,99.925838
        1011.066339,1020.573923,99.90237
        1025.142238,1020.240178,99.911587
        1034.168507,1004.301509,99.602281
        1049.28164,992.438309,99.541444
        1045.509944,986.750619,99.456043
        1026.70047,971.996834,99.763639
        1003.902455,991.625541,99.571882
        1007.982376,1028.739687,99.666664
        1024.432458,1050.097662,101.08374
        1044.260472,1014.620852,101.148239
        1064.304085,989.450915,101.134275
        1079.332153,962.002696,100.848243
        1089.645222,941.189346,100.311875
        1020.982456,939.44901,98.610087
        1013.527321,935.298514,98.521132
        1018.486816,899.700558,98.677255
        1001.102321,897.400163,98.231402
        984.432916,896.728852,98.107135
        1013.757308,953.249984,99.526756
        1005.008462,952.87954,98.928571
        995.625189,962.906458,98.894178
        986.649516,987.386594,99.09342
        981.788023,1001.037428,99.443114
        959.804897,989.74568,98.319992
        959.488753,1000.564305,98.169664
        947.677744,1015.109188,97.876915
        976.468725,1009.732542,99.219763
        989.188118,1008.351768,99.36926
        990.631648,1020.834722,99.261697
        981.915963,1031.09749,98.907372
        1009.786845,1047.904131,99.426804
        997.308417,1042.619927,98.771507
        989.36968,1012.376475,99.747738
        1005.956756,1010.464277,99.839573
          sean
          I can also attach the file in an email to the address you provided in the cloud instructions pdf if that is a working address. cheers
          • Didier BurD
            Didier Bur
            I've tried your file with all kinds of configs (units,snap...) and it works.
            Let's track the bug: open the Ruby console window, launch the script, select the points file and check for error messages in the console.
            Please post the error message if any,
            DB
              sean
              I haven't tried the script on another machine yet as I mentioned via email, but here is the error message I get...
              Error: #<TypeError: nil can't be coerced into Length>
              (eval):305:in *' (eval):305:in draw_geometry'
              (eval):302:in each' (eval):302:in draw_geometry'
              (eval):217:in `onLButtonUp'
              Thanks for your help,
              Sean
              • Didier BurD
                Didier Bur
                HI,
                OK I see where the error seems to be.
                I bet you are not using a decimal format for the units of your model ?
                If you use architectural, engineering or fractionnal, I know how to solve your problem. Please tell me what units you are using ?
                DB
                  Sounds to me like blank lines in the file returning 'nil' ?
                    sean
                    I'm using engineering - feet
                    • Didier BurD
                      Didier Bur
                      OK, that's what I though. Bug is localized...
                      @TIG: i'll do some test on the line contents to skip blank lines or lines not giving 3 coordinates values.
                      DB
                        sean
                        Thank you again...Happy New Year
                          sean
                          Hi again,
                          Were you able to find a solution to the blank lines returning nil?
                          • Didier BurD
                            Didier Bur
                            Yes, (forgot to upload it ๐Ÿ˜ณ )
                            It is here:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15807
                            Regards,
                            DB
                              sean
                              I installed the updated plugin, but I still get the same error message. I also again tried the example.dat file and received the same message. I do not understand how this can be. I appreciate your patience and assistance with this. Do you have any other ideas. My business partner tried it on his machine with the same results. ???
                              • Didier BurD
                                Didier Bur
                                So this is an evidence that either the file format is wrong, or the script settings are wrong.
                                -File format: End of line character ? true ASCII file or not ? Local settings for your decimal separator ?
                                -Script settings: separator "," set OK ?
                                -SU and model settings: what unit are youy using ? (although all possible units are supported).
                                The error message clearly points out that the unit is "nothing" (nil) for the script, or that the first coodinate (X) of the first point is nil.
                                Having tried your small data file here without problem, I wonder what is wrong. Keep searching on this, this will help me improve the script.
                                DB
                                  acmejia
                                  Hi Didier,
                                  I am getting exactly the same problem. I downloaded the latest of your cloud plugin, tried it with both example.dat and a file with three lines written with vi (to ensure it was pure ascii) that had numbers such as
                                  2,3,5
                                  4,6,2
                                  1,2,3
                                  I also tried having a decimal after the numbers
                                  2.01,3.03,5.01, etc...
                                  and having a space for separator.
                                  I am using metric, so the decimal should not be an issue.
                                  I wonder if it is a problem with SketchUp 7 on a mac? I have tried three different versions of cloud, all with different files including example.dat. Always get the same error.
                                  That is too bad because I was so happy when I found your plug in, it is exactly what I need to add some actual data to my galaxy.
                                  Thank you,
                                  Annie
                                    sean
                                    Ah, the blank line skipping solved one issue and the other issue was the unit setting... thank you very much. Is there a way that the guide points created can retain the coordinate data in the entity info? Having the Z coordinate would help identify individual points.
                                    • Didier BurD
                                      Didier Bur
                                      Nope. An attribute could be added but will be invisible in the info box, so useless.
                                      DB
