🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Need BOMB ALL plugin
4 Posts 3 Posters 1.7k Views 3 Watching
  • H Offline
    huyvuvn
    hello ,
    I need a plugin can explode all the groups and components in SU instantly.
    the bomb all ruby in here http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Newest_scripts.html is so good but it sometimes make comptuter crash.
    Do anyone have the others ? Let share to me ^^ thankssss
    happiness on the way, not in the destination.
    • W Offline
      Whaat
      I think the bomb-all plugin could be made much faster on SU7 with a minor modification. Are you using SU7? SU7 should also be more stable and less prone to crashes....
        RickW
        Do you mean the Bomb script from Smustard? Unless you see a BugSplat or a notification from Windows, then it hasn't really crashed - it's just that exploding a lot of groups and components can result in tens of thousands of polygons that have to be added to the drawing as the g/c geometry interacts with the base-level model, and that can take processing time.
        I just tried bomb on a fairly large model - 1500 component instances. It took maybe 30-45 minutes to make it through everything (a rough guess because I wasn't timing the operation). There were times I thought it had frozen up, but it finally made it through the whole model.
        PS - For my test, I tricked it out with the SU7 speed increase capability (I'm afraid to know how long it would have taken had I not used the increase). Will post it sometime this weekend.
        RickW
        [www.smustard.com](http://www.smustard.com)
        • H Offline
          huyvuvn
          thanks 😄
