    SU models of George Hart's geometric sculptures
    62 Posts 18 Posters 9.8k Views 18 Watching
    • H Offline
      HFM
      Hypershot πŸ˜„
      • ArcA Offline
        Arc
        Thank you Pilou and guzman.
        I have played Topmod all day, it's very cool stuff, and I rendered in hypershot.
        http://1.bp.blogspot.com/_xcjlegqdIuM/SUpGnI-cNnI/AAAAAAAAAMk/t5wuEGd0DTA/s320/untitled.84.jpg
        http://2.bp.blogspot.com/_xcjlegqdIuM/SUpErrPrnKI/AAAAAAAAAMU/wGnlV_fCjlg/s320/untitled.86.jpg
        http://1.bp.blogspot.com/_xcjlegqdIuM/SUpEg73tUyI/AAAAAAAAAMM/SIhrdfLycUg/s320/untitled.89.jpg
        http://3.bp.blogspot.com/_xcjlegqdIuM/SUpEGgXIGCI/AAAAAAAAAL8/WdMxMNV8ZtA/s320/untitled.94.jpg
          guzman tierno
          Cool stuff, Arc
          after seeing your drawings I decided I'm gonna have to give TopMod another try,
          thanks for sharing.
          guzman.
            guzman tierno
            If there is anybody interested in modelling geometric sculptures, I wrote I brief tutorial that illustrates one of the possible methods to obtain this kind of models.
            First. Choose a somewhat symmetrical polihedron as a basis for your model.
            For instance: Platonic, Archimedean and Catalan Solids they all work fine.
            They're quite easy to draw but you may of course download them from the 3DWH.
            (Interestingly engough all those solids can be modelled without ever having to type in any measures for sides or angles! Sketchup is so powerful).
            In this brief tutorial I'm going to choose the Truncated Icosahedron, that is:
            the soccer ball:
            http://upload.wikimedia.org/wikipedia/commons/7/7d/Trunc-icosa.jpg
            Second. Choose two or more edges of your polyhedron. It is easier for the subsequent steps if the edges you choose are coplanar (that is, there is a plane that contains them all) but you can also choose non-coplanar edges.
            In this example I'm going to choose the edges shown in the image:
            Three. Create something that connects the edges you've choosen.
            If you want a nice result, it is better to draw something symmetrical. In this example, we have to connect three edges, so I've drawn a component with three-fold simmetry.
            Four. Copy the component that connects the edges in all possible positions,
            until you've covered every edge of the polyhedron.
            You may now want to modify the connecting component to avoid collisions.
            Then erase the polyhedron and just keep the connecting components (skp file attached):
            cagework_2.skp
              bubbalove
              I took a shot at rendering the pencils in Kerky... I think it turned out ok.
              "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                guzman tierno
                Awesome, that's great, I love it
                When I first saw it, I thought it was the image in Hart's site,
                your rendering is really really similar to the original image,
                Really nice work. The colors in particular are just perfect.
                the only thing that may be improved is the model of the pencils I made
                (the edges are too sharp).
                  guzman tierno
                  How to draw an icosahedron without ever typing in any measures.
                  http://upload.wikimedia.org/wikipedia/commons/thumb/b/b7/Icosahedron.svg/385px-Icosahedron.svg.png
                  I know only a few people may be interested in this issue, but I think it's fun when you try.
                  It is actually way easier than it might look.
                  So here's a brief tutorial.
                  1 - Draw a "golden ratio" rectangle, SU will show a tooltip when the rectangle you're are drawing is a golden-ratio rectangle. (I will not discuss here the definition of golden-ratio rectangles and why they are so important, just use them).
                  Select the whole rectangle and make it a group.
                  2 - Select the group and make a rotated copy of it by rotating it around its center by 90Β°:
                  3 - Select the second rectangle and make a rotated copy of it by rotating it around the line shown in the image by 90Β°:
                  4 - Select again the second rectangle and rotate it (no copy) around the line shown in the image by 90Β°:
                  You should end up with three equal rectangles orthogonal to each other.
                  5 - You're done. Just connect the vertices of the rectangles to form triangles:
                  (you may also wanto to erase the rectangles and other internal faces)
                    Taff Goch has plenty of extremely cool tutorials about such shapes. πŸ‘
                      guzman tierno
                      You're right Gaieus,
                      I know TaffGoch tutorials, they're actually a must.
                      I thought however that a step-by-step description could be useful in this thread concerning geometric constructions and sculptures.
                      (But you're right, they're problably off topic in the gallery, I wont post any more)
                      thanks.
                        guzman tierno
                        Here's the last one I made (so far):
                        It is inspired (in the sense that is has the same structure, rhombic triacontahedron) to:
                        George Hart's 12-Part Puzzle
                        mill 3.skp
                          I didn't mean you shouldn't post whatever you like in connection with this thread (although admittedly such a tut would be nice in the respective department as well πŸ˜‰ )
                          And of course I only mentioned Taff here because - well, true, his works are a must πŸ‘
                            guzman tierno
                            TaffGoch also has many cool models related to George Hart's sculptures like this one:
                            http://sketchup.google.com/3dwarehouse/download?mid=21e7435470757928c72bf3eb4f056c1c&rtyp=lt&ctyp=other&ts=1229368575000
                              guzman tierno
                              An idea for the holidays.
                              Cut 30 pieces like this:
                              Then have fun sliding them toghether to obtain this:
                              http://www.georgehart.com/athens/Greece10.JPG
                              Precise instructions and ready-to-print templates: here and here
                              Of course, you can also obtain similar results using sketchup
                              I also built one with colored thick paper and it is actually fun.
                              triacontaedro2.skp
                                Ehm... By sliding them together do I obtain that beautiful lady as well? 😳
                                  guzman tierno
                                  Actual results may vary according to use:
                                    Okay, I stop spamming your topic now.
                                    Keep up the happy modeling! πŸ‘
                                      guzman tierno
                                      No problem, that was fun ...
                                      thanks for your comments.
                                      • plot-parisP Offline
                                        plot-paris
                                        what a cool thread. have to read through all of it at some point. great modeling, guys!
                                          I have made in the past a little tut video for TopMod (sorry in French but very easy to understand πŸ˜‰
                                          (maybe you must wait 15 second for download)
                                            guzman tierno
                                            Thanks plot-paris for your comment,
                                            et merci Pilou pour le tutorial, c'est très bien fait !
                                            guzman.
                                            • 3 / 4
