    Mac Webdialog opens in background
    11 Posts 5 Posters 697 Views 5 Watching
    • W Offline
      Whaat
      Is this a common issue on Mac's with Webdialogs? Do you need to explicity call 'bring_to_front' for the dialog to open in front of the SketchUp window? I don't have a Mac so I can't test this but would the following code work to ensure that the dialog opens in front of the SketchUp window?
      @dlg.show{@dlg.bring_to_front}
      I doubt that the following would work:
      @dlg.show{}
      @dlg.bring_to_front
      OR
      @dlg.bring_to_front
      @dlg.show{}
      Thanks.
      • W Offline
        Whaat
        ...still having no success with getting Mac Webdialogs to open 'on top'. Doesn't anyone know the solution?
        • BurkhardB Offline
          Burkhard
          edited...does not work.
          [http://www.ia-plus.de(http://www.ia-plus.de)]
          • W Offline
            Whaat
            Here's another idea. Does anyone know of any Ruby script that has a working Webdialog for Mac's (i.e. dialog does not open in background).
            • BurkhardB Offline
              Burkhard
              I tried several with no luck. That was my idea as well.
              The only one I know are from Google 😉 ( If the instructor/ mentor is one of them )
              • scottliningerS Offline
                scottlininger
                Here's what I do: I detect if the user is on a mac, and if so I open the dialogs with "show_modal". Modal dialogs on the PC are truly modal, meaning when they're visible you can't click on anything else in SketchUp, but on the mac they aren't truly modal... they just float on top of everything.
                if is_mac == true
                  dialog.show_modal
                else
                  dialog.show
                It's a bit hacky, but it works.
                • Scott Lininger
                  SketchUp Software Engineer
                  Have you visited the Ruby API Docs?
                • W Offline
                  Whaat
                  Hacky shmacky...thankyou so much!!
                    Not-Really-Modal modal window... would never have though of trying that.
                    I feel there should be a list of SU Ruby tricks. And this should be on the list.
                    btw,how do you find out if SU is running on a mac?
                      azuby
                      PLATFORM = (Object;;RUBY_PLATFORM =~ /mswin/i) ? ;windows ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? ;mac ; ;other)
                      edit: It's a one-liner.
                      azuby
                      *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                      Bad English? PM me, correct me. :smile:**
                        Just had another though, if you really want a modal window on mac? Not possible?
                          scottlininger
                          Not currently possible, unfortunately.
                          • Scott Lininger
