    Some plugins don't work SU 7. Organizer.rb at fault?
    19 Posts 5 Posters 3.1k Views 5 Watching
    • C
      CalypsoArt
      Tried the ruby console test. All resulted with "true". I take this to mean that they were loaded correctly yet I cannot find them anywhere--not under plugins, draw, tools, or right click. Suggestions?
      • L
        L. Banasky
        Please, I would also appreciate some help getting beamtool.rb to work with 7, it works fine with 6.
        The error message states that "Win32API.so" cannot be found or loaded, yet it is in the Plugins folder.
        I'm using Vista32.
        Thanks, Larry
        • L
          L. Banasky
          Please, anyone have a clue why CadalogBeamTool.rb does not work?
          I have included the error message.
          Thanks, Larry
            stanmarsh
            according to the error, your missing the win32api.so, better to download the cadalog beam tool again.
            • L
              L. Banasky
              Thanks,
              The file seems to be there. I downloaded and tried again, still no success. I am including the beamtool.zip file, if anyone would be willing to try it on SU7 Vista32.
              Thanks, Larrybeamtool.zip
                RickW
                Let's stick with SpiralStair for now (though the others should be similar).
                Spiral Stair should load in the Plugins folder unless you organized it into a subfolder. In that case, under "Plugins" there should be a submenu with the same name as the subfolder on your hard drive. SpiralStair should be in that submenu. However, since it loaded from the ruby console, it is probably located in the Plugins folder/menu (unless you copied it into the subfolder).
                Can you post the spiralstair11.rb file? or PM it to me?
                RickW
                www.smustard.com
                • L
                  L. Banasky
                  Rick,
                  Enclosed is the spiralstair11.rb. I just moved it to the Plugins folder (SU7, Vista32)and it works fine. Now the CadalogBeamTool.rb......a mystery.
                  Larryspiralstair11.rb
                    RickW
                    I suspect (but can't confirm) there might be a problem with the Win32API.so file on Vista. Anyone else?
                    RickW
                    www.smustard.com
                    • L
                      L. Banasky
                      Thanks Rick, I'm using CadalogBeamTool.rb with SU6 on Vista, and it works fine. I would like to use it with SU7. I don't understand how these work, and was wondering if using Organizer.rb would help.
                      Thanks, Larry
                        RickW
                        All Organizer does is allow the user to create subfolders in the Plugins folder, then drop scripts into the subfolders. In SketchUp, the subfolders appear as submenu items in the Plugins menu, and the scripts appear in their respective subfolders.
                        If something isn't already working in SU7, Organizer won't suddenly make it work (though I wish it did) 😄
                        For your CadalogBeamTool, did you extract the "cadalog" folder and its contents to your Plugins folder? You need more than just the .rb file.
                        RickW
                        www.smustard.com
                        • L
                          L. Banasky
                          Thanks Rick,
                          Yes everything is in the Plugins folder, it is exactly like my SU6 Plugins folder using Vista on the same PC. As a last resort, I might install SU7 on the C Drive, I don't really like to do that, but it is worth a try.
                          Larry
                            RickW
                            Open the ruby console (Window>Ruby console) and type
                            load "CadalogBeamTool.rb"
                            and press <Enter>
                            If any notifications appear in the console, copy and paste them in a post here and we'll try to troubleshoot this some more.
                            RickW
                            www.smustard.com
                            • L
                              L. Banasky
                              Thanks again for your time and help. I installed on C drive, no changes. I entered the text in the Ruby console, with a space and without a space, enclosed are the results.
                              • L
                                L. Banasky
                                CadalogBeamTool.rb is now working. I did a side by side comparison of the files in the main program folder of SU6 and SU7, and moved the missing files from SU6 to SU7 one by one. The file that is required by SU7 that is missing is msvcr71.dll. I tried to enclose the file, but .dll's are not allowed.
                                Thanks again for all your help,
                                Larry
                                  RickW
                                  Glad you got it working finally! 😄
                                  RickW
                                  www.smustard.com
