    Rounded boxes problem
    7 Posts 4 Posters 615 Views 4 Watching
    • F Offline
      Fatolbaldguy
      Very very new at this and I am sure you have probably been beating this dead horse for awhile but I have read every tutorial I can find! I make a rounded box in four parts rounding three sides duplicating and mirror imaging the pieces. I then put them together and intersect them to make one big box with rounded sides. Seems to work OK, but when I start trying to remove the un-needed lines on the box faces sometimes (Not always) the whole face disappears. I can't seem to find any rhyme or reason to it. What am I doing wrong. Is there a better way to create the rounded box?
      Due to financial constraints the light at the end of the tunnel will be extinguished until further notice.
      • H Offline
        Hazza
        Yes, make a normal hard edge box then use the "Round edges" plugin that you can download from this thread.
        See all of my SketchUp models here.
          I have another guessing shot...
          There seems to be a bug in SU (haven't tried with version 7 yet) that when you join two parts that have a fairly big number of faces each, you cannot delete the seam between them without unwantedly deleting the connecting faces as well despite the are definitely coplanar. Is that you are talking about?
          If so, make a group of the half first then copy > mirror it then align the two copies of the group, explode and try to delete the seam now.
          This trick or workaround seems to fix this bug but no-one knows why the bug is there and why this workaround fixes it.
          If this is not the problem, sorry for talking too much.
          • F Offline
            Fatolbaldguy
            Exactly! I thought I was missing a step or just screwing up in general! Thanks for the work around. Now I need a couple of wife/kid/dog free hours I can rub together to really make things happen (I hope) Thanks again!
            • F Offline
              Fatolbaldguy
              OK long as I'm showing my ignorance anyway.
              I can't get the plugin to load. Anyone have a tutorial for the criminally computer challenged on loading these things?
                remus
                1)Download the plugin to an easily accessible location, like your desktop.
                2)Open your plugins folder (my computer->c->program files->google->sketchup->plugins)
                3)drag the .rb file from your desktop in to the plugins folder.
                4)restart SU and hey presto! You should have the plugin in one of the menus (tools, plugins, right click menu etc.)
                • F Offline
                  Fatolbaldguy
                  Thank You. That did it. Big time saver! Now to learn to use it to best advantage.
