    Creating a sail
    18 Posts 9 Posters 1.6k Views 9 Watching
      skaught
      http://farm4.static.flickr.com/3092/3083237022_9deae64861.jpg?v=0
      Hello out there...
      I created this sail by drawing the basic wire frame and then stitching it together... I'm sure there is an easier/cleaner way to do it.
      Can someone let me know what that way is?
      I had created a sail once before by using the follow me tool to wrap one edge of the sail around an outside curve and then intersected all of the parts on the bottom that I needed cut-out....then used the rotate tool to bring the top to a point. This way was also a little messy and a pain in the a$$. Any help would be appreciated, as I am going to be drawing a number of these sails in slightly different shapes.
      • david_hD Offline
        david_h
        There are a couple of tools for doing this. . .
        SoapSkinBubble and SubSmooth Tool. Check around the forum and you'll find links.
        D
        • soloS Offline
          easy sail 1
          easy sail1.skp
          • david_hD Offline
            david_h
            D
              skaught
              The last step of the tutorial you posted has a call-out..."using FFD, shape according to needs"...
              What is FFD?
                skaught
                Thank you both.
                • soloS Offline
                  Easy sail 2
                  http://img126.imageshack.us/img126/9567/easysail2ce9.jpg
                  easy sail2.skp
                  • soloS Offline
                    Those are plugins, FFD and Subdivide in the last one.
                    Do a search for 'sketchy FFD' and 'sub divide and smooth', they are two plugins of many that one needs (yes, needs) for SU to be powerful.
                      skaught
                      awesomeness. I will post the results. thanks again.
                      • boofredlayB Offline
                        boofredlay
                        Here is a sail using the Sandbox tools that come with SU. No plugins.
                        As was said before, there are many ways to do this.
                        Sandbox Sail.skp
                        • david_hD Offline
                          david_h
                          The little stars represent the FFD points. Used Carpet is not the best material for a sail . ..but I'm poor. 💚carpet sail.jpg
                            This was made with Soap Skin and Bubble a while ago:
                            http://sketchup.google.com/3dwarehouse/details?mid=a5ba1c856e92ac33ebdf91bf2ffe7e7
                            • V Offline
                              vieucaillou
                              Hello !
                              This typically the case where plugin SSB is appropriate. You may even adjust the windforce into the sail. 😉
                              http://escargot-archi.eu
                              • Jean LemireJ Offline
                                Jean Lemire
                                Hi Skaught, hi folks.
                                Continuing on Solo's first idea, you can punch a triangular shape in a spherical surface instead of a cylindrical one.
                                Just ideas.
                                  ridix
                                  Technically sail is an airfoil. So, one of the way to model it is to lay down base airfoil section first. Copy it number of times along the height of the sail. Scale down each section and connect it all. Well, if you want to model it to real shape, sail needs to twist as it go up too; the unsupported side of sail tends to get pushed away with wind load. It all works out as airfoil, because wind aloft is stronger than at the boom. If you are racer, this airfoil needs to be in prefect form to get the maximum power out of wind.
                                  http://www.designonme.com/sketchu/sail.gif
                                  • david_hD Offline
                                    david_h
                                    I think with all of the input Skaught is getting on sails (s)he could've modelled Old Ironsides by now. 😄
                                      skaught
                                      http://farm4.static.flickr.com/3150/3085425922_c8eb8e8940.jpg?v=0
                                      Much quicker and much cleaner...
                                      I used the FFD plug-in on a flat shape (some horizontal lines across the shape helped to make it a little smoother across the middle when distorting).
                                      Although, it took a few tries to get it smoothed out right, it was much faster than my previous attempt. It's actually not a sail.... (air foil lol), but a piece that will be formed out of resin and attached to a larger display (to promote that "sailing feel")....hopefully.
                                      I was going to try the Sub Devide and smooth tool (watched the tutorial on smustard.com...looked really cool) but it costs $22 bucks. Will check out the rest...
                                      This is the second time I have asked for help in these forums and the second time i have been amazed at the response. Thanks to all....a lot.
                                        You have a free Version of Subdivide at Smustard by Rick Wilson 😉
                                        Less elaborated but useful too ☀
