    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Solo Town
    34 Posts 24 Posters 6.6k Views 24 Watching
      ccs
      Pete.
      All of the renders capture a number of different details. From architectural to environmental. I have to say my favorite is the dusk one. The sky is what enhances the entire look. The reflections are for me the icing on the cake. They add their own depth to an incredible scene. Incredible detail without being overdone.
        steelers05
        Awesome stuff. Vegetation done in vue?
          kwick7
          Looks awesome!
          I'd love to give Vray a try, but I just can't justify the price.
          http://www.bigmug.net
          • soloS Offline
            Thanks guys.
            Steelers, yes the color vegetation is Vue, the 3D mesh ones are from 3D tree generator.
            I have done the apartment (flats) and added it to scene, unfortunatly I have come to the end of SU as a tool from here and will need to continue in Max as SU's poly limit is about reached.
            These are both Podium 1,6
            http://img216.imageshack.us/img216/548/scene7noisyqz6xb5.jpg
            http://img84.imageshack.us/img84/3646/scene8noisy7hj0.jpg
            Larger versions here: http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=3135669&pid=30309446#post30309446
              Karlfucious
              Beautiful work. Are the roof tiles modeled or displacement?
              • FrederikF Offline
                Frederik
                Pete... I'm impressed..!! ๐Ÿ˜ฎ
                You seem to be able to surprise me (in the most positive way..!!) over and over again...!!! ๐Ÿ‘
                Cheers
                Kim Frederik
                  decipher
                  If you fancy uploading or sending the skp i can run it through maxwell render, i recon it would make a good comparison!
                  (although obviously maxwell takes a little longer!)
                  http://www.3dfilter.com
                  The 3D Model and texture search engine
                  • soloS Offline
                    Thanks again guys.
                    Karlfucious, there is no bumps, displacement or textures, everything is modelled, every brick, roof tiles, etc.
                    Decipher, I would like to but seems that the models are to be purchased after all, with an additional three that I have still to do.
                    • EarthMoverE Offline
                      EarthMover
                      Pete,
                      When you say continue in Max, do you generally just assemble your scene in Max and continue to model in SU? I'm really curious about your Max/SU integration. Do you do any rendering in Max?
                      Content Creator at Skapeup
                      • soloS Offline
                        Adam,
                        It's been a long time since I played with Max as far as modeling goes (not that much in the GUI has changed over the years) , so no I will just assemble there as it will handle high poly's with ease (even with the choking SU at at same time), I mentioned about a client that wanted something similar who has decided to take these plus a few others, I normally dispatch in .ma or .max for him to forward to his 'texture guy' for completion.
                        I do however render in Max occassionaly, normally for studio pre production product illustrations using Mental-ray, but that market was very niche and has slowed down to a crawl due to current economic conditions.
                          EarthMover
                          Pete,
                          Yeah, we are feeling the hurt from the economy as well. Hope things get back to normal soon.
                          You should check out this plugin for Mental Ray - http://www.3dtotal.com/services/pluggins/bluecherry_shop.asp It turns Mental Ray into Podium. ๐Ÿ˜„ ....and it's only $15.
                          • 2 / 2
