    Solo Town
    34 Posts 24 Posters 8.3k Views 24 Watching
    • H
      Huggkruka
      My favourite is the first render with plants in it. It looks so slick, I felt like giving you money.
      • soloS
        Whiteout.
        http://img355.imageshack.us/img355/7259/flatsdy9.jpg
          Mannie
          Getting better and better ๐Ÿ˜‰, nice vue render there
          • C
            ccs
            Pete.
            All of the renders capture a number of different details. From architectural to environmental. I have to say my favorite is the dusk one. The sky is what enhances the entire look. The reflections are for me the icing on the cake. They add their own depth to an incredible scene. Incredible detail without being overdone.
              steelers05
              Awesome stuff. Vegetation done in vue?
              • K
                kwick7
                Looks awesome!
                I'd love to give Vray a try, but I just can't justify the price.
                http://www.bigmug.net
                • soloS
                  Thanks guys.
                  Steelers, yes the color vegetation is Vue, the 3D mesh ones are from 3D tree generator.
                  I have done the apartment (flats) and added it to scene, unfortunatly I have come to the end of SU as a tool from here and will need to continue in Max as SU's poly limit is about reached.
                  These are both Podium 1,6
                  http://img216.imageshack.us/img216/548/scene7noisyqz6xb5.jpg
                  http://img84.imageshack.us/img84/3646/scene8noisy7hj0.jpg
                  Larger versions here: http://www.websitetoolbox.com/tool/post/supodiumforum/vpost?id=3135669&pid=30309446#post30309446
                  • K
                    Karlfucious
                    Beautiful work. Are the roof tiles modeled or displacement?
                    • FrederikF
                      Frederik
                      Pete... I'm impressed..!! ๐Ÿ˜ฎ
                      You seem to be able to surprise me (in the most positive way..!!) over and over again...!!! ๐Ÿ‘
                      Cheers
                      Kim Frederik
                        decipher
                        If you fancy uploading or sending the skp i can run it through maxwell render, i recon it would make a good comparison!
                        (although obviously maxwell takes a little longer!)
                        http://www.3dfilter.com
                        The 3D Model and texture search engine
                        • soloS
                          Thanks again guys.
                          Karlfucious, there is no bumps, displacement or textures, everything is modelled, every brick, roof tiles, etc.
                          Decipher, I would like to but seems that the models are to be purchased after all, with an additional three that I have still to do.
                          • EarthMoverE
                            EarthMover
                            Pete,
                            When you say continue in Max, do you generally just assemble your scene in Max and continue to model in SU? I'm really curious about your Max/SU integration. Do you do any rendering in Max?
                            Content Creator at Skapeup
                            • soloS
                              Adam,
                              It's been a long time since I played with Max as far as modeling goes (not that much in the GUI has changed over the years) , so no I will just assemble there as it will handle high poly's with ease (even with the choking SU at at same time), I mentioned about a client that wanted something similar who has decided to take these plus a few others, I normally dispatch in .ma or .max for him to forward to his 'texture guy' for completion.
                              I do however render in Max occassionaly, normally for studio pre production product illustrations using Mental-ray, but that market was very niche and has slowed down to a crawl due to current economic conditions.
                              • EarthMoverE
                                EarthMover
                                Pete,
                                Yeah, we are feeling the hurt from the economy as well. Hope things get back to normal soon.
                                You should check out this plugin for Mental Ray - http://www.3dtotal.com/services/pluggins/bluecherry_shop.asp It turns Mental Ray into Podium. ๐Ÿ˜„ ....and it's only $15.
                                • 2 / 2
