Sketchup-puncturing a hold through a rectangle?
I've built a staircase that is two stories high. I'm now working on the second story, and am trying to create a hole in the floor ( a 5' slab/rectangle that I drew under my plan and push pulled) so that you can see that there is an opening where you'd come up from the 1st floor up to the second floor. I can't seem to puncture that hole in the floor so you can see that. I've drawn a rectangle, push pulled it through both the top and bottom face of the floor and it won't puncture though. I've tried using intersect and deleting the rectangle I extruded, but nothing seems to create a hole in this slab for descending stairs. Is there any advice you can give me to make a hole?
Much appreciated,
Kim
If you could post the model it would be easier to give specific advice, but from your description: make sure the stuff your intersecting isnt grouped, as this could change where the intersections are created.
Have you grouped your floors?
