    How do I convert a skp file to exe !!
    12 Posts 5 Posters 3.9k Views 5 Watching
    • B
      basilkov
      Hey ! I wrote a pre thread but I cant see it for some reason ! plz tell me how to convert my "skp" file sketchup7 to "exe" its actually an assignment and I need the doctor see it in exe format ! he would not download skp to see it !
      edit: one more thing .. about animation ! I've found that "SU Animate plugin" but evaluate ! whats the exact difference between it and between the full plugin ? and how do I make a box to rotate and keep rotating ?!
        remus
        You cant export an SU animation as a .exe file, although you can export it in a video format (.avi.) To do this, go file->export->animation then use the drop down menu at the bottom of the window to change the file format to .avi.
        I'll let someone else explain about SU animate, as i dont use it myself.
        • B
          basilkov
          thanks man for ur reply but when I make this avi video it does not move ( I mean the camera ! ) I made 6 frames (tabs) and I changed the views in each one ! but nothing happened ! its the same view ! I hope somebody who uses SU Animate help me before the evaluation period of this plugin exceeds .
            remus
            Could you post the file up by any chance? sounds like something weird might be happening.
            • Chris FullmerC
              And make sure you're using the right scene creation workflow.
              Move to the position you want to see.
              Add a scence
              Move to the next position
              Add a scene
              repeat as needed.
              • B
                basilkov
                ok man I uploaded it and send the link to ur private messages ! cuz some ppl out there may take it and modify it .. u understand me right ? plz check ur pm.
                • B
                  basilkov
                  Add a scence
                  Add a scene
                  repeat as needed.
                  U mean this works to animate the box ? make it rotate ? by making just scenes ! my purpose is to keep rotating the box then make a video showing that the project is in 3d ( in different views as u told me ).
                  edit : can I send u the link of the project on your PM ?
                  • Chris FullmerC
                    Sure you can send me a link to your project. I'll look at it too.
                    The thing about SketchUp's animations is that the model itself does not get animated. But you can animate a walkthrough through the model. I'll upload a simple model to show you what I mean. Just click from one tab to the next to see what happens. Then lets sey you wanted to export a video, you would go to File>Export>Animation and you could export an animation video for others to watch to see your model, but as a video.
                    simple flythrough.skp
                      AdrianM
                      The eDrawings publisher will let you export a Sketchup file to an exe file.
                      • GaieusG
                        Yes, but it's PC only (AFAIK) and will instll a viewer as well which many users don't really like.
                        • Chris FullmerC
                          OK, so I looked at your model now and it is as simple as I explained before. Follow the step I explained and it will work. I can tell you haven't tried it yet.... So here's a video showing how to do it.
                          [flash=639,508:1s6djsdx]http://content.screencast.com/users/clf23/folders/Jing/media/6046e45c-b94a-4ecb-82ea-b1cddc75214d/simpe animation creation.swf[/flash:1s6djsdx]
                          When you export the video like I showed, it will create an avi file, which ic a standard video file, that your lecturer can play and see that you did indeed make a 3d box.
                          • B
                            basilkov
                            [flash=639,508:3gv34453]http://content.screencast.com/users/clf23/folders/Jing/media/6046e45c-b94a-4ecb-82ea-b1cddc75214d/simpe animation creation.swf[/flash:3gv34453]
                            yes mate I made all this .. ! but my problem now is rotating the box about itself and stay on the table! MEMBER remus told me a trick of using layers but cant manage to make it work !
