    SU7 Stuck In Wire Frame Mode? Invisible Faces.
    4 Posts 2 Posters 572 Views 2 Watching
      davidshere
      Hello/Help! Downloaded Su7 and can't figure out why there are no faces showing. Seems to be in wire-frame mode. When i select the different styles there is no change in the wire-frame look. Even if i import a model from SU6 it still is stick figures, however, i can push and pull and select faces. I have a Gateway (uhhg) running Vista (uhhhhg) with 2gig ram. Everything worked fine in SU6. Thanks in advance, David
      when am i where?
        Hi David,
        To make a quick test,go to Window >Preferences > OpenGL and try to play with the settings (especially turning off Hardware acceleration).
          davidshere
          ha. new it had to be under my nose. thanks or taking your time. David
          when am i where?
            No David,
            This is just a diagnostic test that there is something wrong with your video card/driver.
            You should update your driver to be fully compatible with OpenGL (thus SU) in order to work better on large models as well.
