    "ISSUE" With Face Selection -- SOLVED (See final post)
    12 Posts 4 Posters 1.1k Views 4 Watching
    • Chris FullmerC Offline
      It is possible that it is related to graphics card drivers. You might just check to see if you have the newest drivers. You might also play around with hardware acceleration settings and fast feedback. They are in the SU preferences menu.
      If that doesn't work, maybe a screenshot could help shed more light on the matter?
        You could definitely try to reinstall to see if that helps. Any chance you could post the model? Or stripped down version of the problem?
          Louisaz
          Chris,
          You bet. I'll be happy to send it to you tonight -- it's on my home PC. What address should I use? It looks like I can "upload" an attachment to one of these messages. If I upload it as an attachment to a Forum message, will you be able to download it and minipulate it?
          It's a small model that ONLY contains a few interior walls for a "test" house. [When SU stopped being able to select the faces, I stopped constructing the model.]
          I was experimenting with a methodology for rapidly drawing a 2-D floor plan using "parallel projection."
          I have NO issues with SU on my older and slower office PC -- using the same construction techinques. Hmmm. My home PC monitor has a "wide screen" display format. I wonder if I have to change an SU settings [or monitor settings] to work with SU.
          Thanks,
          Louis
            Yeha, great. Please just upload it here. The benefit in that is you often get others who are willing to look at it and might respond faster or more reliably πŸ˜„
              Louisaz
              Chris and James....
              I'll upload it tonight as a reply to this message string. Let me know if you have the same issue with the faces on your PCs.
              I suspect it is a PC-specific issue. I've done a similar test model on my office PC [without ANY issues] that I will e-mail to myself and open it tonight on my home PC. IF I have an issue with the office-generated model on my home PC, that narrows the possibilities [e.g., corrupted SU installation; wide-screen monitor format issue; or, some unknown command issue...].
              Thanks,
              Louis
                Louisaz
                Chris,
                Thanks for advice. However, the (home) PC I'm using is a current, late model Dell with a dual-core Intel processor, 2 gigs of RAM. I've been modeling on the PC, using AutoCAD and SU, for some time WITHOUT similar issues. On my office PC [an earlier and slower Pentium 4] I don't have the issue.
                It seems to be related to HOW I'm creating the model -- or a setting that I've mistakenly changed.
                I'm considering removing SU and reinstalling it. What do you think?
                Louis
                  Louisaz
                  I am attaching the offending document. Again, the problem is my HOME PC is having "issues" selecting faces.
                  I have tried the WINDOWS > PREFERENCES > OPEN GL > CORRECT REVERSED PICKING DRIVER BUG. That didn't work.
                  I've sent an e-mail to SU Tech Support for SU Pro 6 and will let you know what they say.
                  Thanks,
                  Louis
                  Try to select the faces on this puppy
                    Kenny
                    I'm on Windows XP and it works perfectly in versions 6.0 and 7.0.
                    http://www.townscapesolutions.co.uk/
                      pmiller
                      Does you home PC have, by any chance, an integrated graphics card (eg Intel chipset) rather than a separate graphics card? Integrated graphics are notorious for the face selection problem as they do not properly support OpenGL. If so, you are probably out of luck and will need to get a separate graphics card (preferably nVidia).
                      One way to check for certain is to turn off hardware acceleration in OpenGL preferences. If you then can select faces you have confirmed the graphics chip problem.
                        Louisaz
                        Paul,
                        Thanks for the suggestion. Yes, the Dell Vostro I purchased does use an integrated graphics accelerator. I, too, thought THAT was the issue. But wait...
                        I messed around with the WINDOWS > SYSTEM PREFERENCES > OpenGL > and CHECK the "Correct reversed picking driver bug" and UNCHECK the other two [Use hardware accelerator and Use fast feedback]. That did the trick. [Simply checking the bug fix didn't do it...you have to UNcheck the other two options.]
                        It's working as it should ... 😍
                        Louis
                          Excellent, glad it worked out! Glad others were able to chime in with ideas,
