    [Question] Icon pressed
    15 Posts 5 Posters 1.1k Views 5 Watching
    • CadFatherC Offline
      CadFather
      i have replicated some sketchup icons - i have made a script where i use
      Sketchup.send_action "selectArcTool:"
      the script works but the problem is that the icon does not remain pressed - i have looked at validation_proc but i cannot seem to implement it.. am i looking in the right place?
      can someone write a quick snip for me?
      Max
        CadFather
        i scared you, eh?
          CadFather
          wow Matt - i thought all i had to do was to check that the 'send.action' had worked: select the arc tool > check that it is active > return value (piece of cake)
          i didn't imagine i was stepping into such quicksands - no wonder even a genius like me couldn't figure it out. πŸ’š
          Thanks!!! πŸ˜„
            Matt666
            Here is a small code to retrieve all Tool IDs...
            Enter "retrieve_ToolID" in the ruby console, and click on each icon you want to retrieve. The id will be returned in the console πŸ˜‰
            retrieve_ToolId.rb
            Frenglish at its best !
            My scripts
              CadFather
              well Matt, it works great - i will try to implement the other icons and see where i get.
              if the global variable conflicts with others i shall find out! (and cry for help! πŸ˜‰ )
                Matt666
                Hi CadFather !
                Sorry, but your demand is quite difficult πŸ˜„
                Yes, but also a tool observer.
                I found one solution, but I use a global variable... I've asked ruby masters how to not use it, I wait for the answer...
                For the moment, here is the test I've made.
                The Observer Code :
                class ToolsObsTest < Sketchup;;ToolsObserver
                	def onActiveToolChanged (tools_object, toolname, toolid)
                		$id_of_the_changed_tool = toolid #Global variable that record ID of the new tool activated
                The code that give you the action of the icon, and its validation
                module Matt_Test
                	#Code that been used for all your icons
                	def self.t1(action) # Action = Name of the action to send to Sketchup
                		model = Sketchup.active_model
                		model.tools.add_observer(ToolsObsTest.new) # Activate the Tool observer
                		Sketchup.send_action(action) # Send the action you need
                	# Code for the validation of the icon.
                	def self.obs(id) # ID = Id of your Icon action
                		if $id_of_the_changed_tool && id == $id_of_the_changed_tool #if ID of the tool activated = ID of your icon
                			return MF_CHECKED
                		else
                			return MF_UNCHECKED
                Loading icon and the tool associated
                if not file_loaded?("observerTest.rb")
                	plugins = Sketchup.find_support_file("Plugins")
                	tb = UI;;Toolbar.new("Observer Test")
                	cmd = UI;;Command.new("TestCircle") { Matt_Test.t1( "selectCircleTool;" ) } # Here, the icon action is "Circle".
                	cmd.small_icon = cmd.large_icon = File.join(plugins,"f2f_cursor.gif") # Put another icon name if you want to try ;)
                	cmd.tooltip = cmd.status_bar_text = "Test -> T1 ; Circle & ObserverTest"
                	cmd.set_validation_proc { Matt_Test.obs 21096 } # 21096 = Circle.
                	tb.add_item cmd
                file_loaded("observerTest.rb")
                Don't hesitate to tell me if you need help for all your icons.
                EDIT1 : Code updated. No global variables in the code πŸ˜‰
                you have to use this script like a function. Please see below how to use it.
                Just the code.
                My scripts
                  Matt666
                  Hi cadFather !
                  I've updated the script in the attachment post.
                  Don't modify this file, please! And don't add anything after. Just place the icon_observer script in the plugins folder.
                  Create a new file to put your icons code. To call the icon_observer, you have to put this line at the beginning of your icon script :
                  require 'icon_observer.rb'
                  Now use codes below to use this script :
                  Icon_Observer.go ( Name of the action )
                  cmd = UI;;Command.new("Circle") { Icon_Observer.go( "selectCircleTool;" ) } # Here, the icon action is "Circle".
                  Icon_Observer.obs ( ID of the tool )
                  cmd.set_validation_proc { Icon_Observer.obs 21096 } # 21096 = ID of the Circle Tool.
                  Enjoy ! πŸ˜„
                  My scripts
                    CadFather
                    Thanks Matt!!!!!!!!!!!!!!
                    will report back.. πŸ˜„
                      CadFather
                      Matt, is it possible to use the id in the first part? -
                      for example:
                      cmd = UI::Command.new("Circle") { Icon_Observer.go( 21096 ) }
                      when i tried it didn't work..
                      SUPER EDIT: sorry Matt..it DOES work!! 😲 πŸ˜„ πŸ‘
                        CadFather
                        Hi Matt
                        i'm getting a console error of "retrieve_ToolID" in version 7 -
                        Error; #<NameError; (eval);145; undefined local variable or method `retrieve_ToolID' for main;Object>
                        (eval);145
                        is it fixable? (if/when you have a bit of time) πŸ˜‰
                        basically i'm trying to find the id for the new DC icons
                          Matt666
                          Hi CadFather !
                          Perhaps the case of the text... I don't have Su 7, so can you try this :
                          retrieve_ToolId
                          Your 'D' is 'd' in the code...
                          πŸ˜‰
                          My scripts
                            CadFather
                            😲, πŸ˜’, πŸ‘, 😳, πŸ’­
                            THANKS! πŸ˜„
                            only one tool shows the id - the others are ruby calls in .rbs files i cannot access.. 😞
                              googlo
                              πŸ˜„ πŸ˜„ πŸ˜„
                              THX!
                                Gultekinmg
                                inject that into your code..at "icon_observer.rb"
                                >> p "This is SU Bug.."
                                and watch them scroll all the way eternity....
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  NO do NOT do this !
                                  1. ONLY determine if the return value of the validation proc is MF_CHECKED, MF_GRAYED or MF_ENABLED.
                                  2. Keep conditional evaluations (and any other,) at the bare minimum.
                                  ALL visible toolbar validation procs are called by the Sketchup application's main loop, each time the user interface needs to be redrawn (including each time the mouse is moved !!) Menu validation procs are called when a specific menu needs to be displayed.
                                  I'm not here much anymore.
