    [Question] Icon pressed
    15 Posts 5 Posters 1.5k Views 5 Watching
      Matt666
      Here is a small code to retrieve all Tool IDs...
      Enter "retrieve_ToolID" in the ruby console, and click on each icon you want to retrieve. The id will be returned in the console πŸ˜‰
      retrieve_ToolId.rb
      Frenglish at its best !
      My scripts
      • CadFatherC Offline
        CadFather
        well Matt, it works great - i will try to implement the other icons and see where i get.
        if the global variable conflicts with others i shall find out! (and cry for help! πŸ˜‰ )
          Matt666
          Hi CadFather !
          Sorry, but your demand is quite difficult πŸ˜„
          i have looked at validation_proc but i cannot seem to implement it.. am i looking in the right place?
          Yes, but also a tool observer.
          I found one solution, but I use a global variable... I've asked ruby masters how to not use it, I wait for the answer...
          For the moment, here is the test I've made.
          The Observer Code :
          class ToolsObsTest < Sketchup;;ToolsObserver
          	def onActiveToolChanged (tools_object, toolname, toolid)
          		$id_of_the_changed_tool = toolid #Global variable that record ID of the new tool activated
          The code that give you the action of the icon, and its validation
          module Matt_Test
          	#Code that been used for all your icons
          	def self.t1(action) # Action = Name of the action to send to Sketchup
          		model = Sketchup.active_model
          		model.tools.add_observer(ToolsObsTest.new) # Activate the Tool observer
          		Sketchup.send_action(action) # Send the action you need
          	# Code for the validation of the icon.
          	def self.obs(id) # ID = Id of your Icon action
          		if $id_of_the_changed_tool && id == $id_of_the_changed_tool #if ID of the tool activated = ID of your icon
          			return MF_CHECKED
          		else
          			return MF_UNCHECKED
          Loading icon and the tool associated
          if not file_loaded?("observerTest.rb")
          	plugins = Sketchup.find_support_file("Plugins")
          	tb = UI;;Toolbar.new("Observer Test")
          	cmd = UI;;Command.new("TestCircle") { Matt_Test.t1( "selectCircleTool;" ) } # Here, the icon action is "Circle".
          	cmd.small_icon = cmd.large_icon = File.join(plugins,"f2f_cursor.gif") # Put another icon name if you want to try ;)
          	cmd.tooltip = cmd.status_bar_text = "Test -> T1 ; Circle & ObserverTest"
          	cmd.set_validation_proc { Matt_Test.obs 21096 } # 21096 = Circle.
          	tb.add_item cmd
          file_loaded("observerTest.rb")
          Don't hesitate to tell me if you need help for all your icons.
          EDIT1 : Code updated. No global variables in the code πŸ˜‰
          you have to use this script like a function. Please see below how to use it.
          Just the code.
          My scripts
            Matt666
            Hi cadFather !
            I've updated the script in the attachment post.
            Don't modify this file, please! And don't add anything after. Just place the icon_observer script in the plugins folder.
            Create a new file to put your icons code. To call the icon_observer, you have to put this line at the beginning of your icon script :
            require 'icon_observer.rb'
            Now use codes below to use this script :
            Icon_Observer.go ( Name of the action )
            cmd = UI;;Command.new("Circle") { Icon_Observer.go( "selectCircleTool;" ) } # Here, the icon action is "Circle".
            Icon_Observer.obs ( ID of the tool )
            cmd.set_validation_proc { Icon_Observer.obs 21096 } # 21096 = ID of the Circle Tool.
            Enjoy ! πŸ˜„
            My scripts
              CadFather
              Thanks Matt!!!!!!!!!!!!!!
              will report back.. πŸ˜„
                CadFather
                Matt, is it possible to use the id in the first part? -
                for example:
                cmd = UI::Command.new("Circle") { Icon_Observer.go( 21096 ) }
                when i tried it didn't work..
                SUPER EDIT: sorry Matt..it DOES work!! 😲 πŸ˜„ πŸ‘
                  CadFather
                  Hi Matt
                  i'm getting a console error of "retrieve_ToolID" in version 7 -
                  Error; #<NameError; (eval);145; undefined local variable or method `retrieve_ToolID' for main;Object>
                  (eval);145
                  is it fixable? (if/when you have a bit of time) πŸ˜‰
                  basically i'm trying to find the id for the new DC icons
                    Matt666
                    Hi CadFather !
                    Perhaps the case of the text... I don't have Su 7, so can you try this :
                    retrieve_ToolId
                    Your 'D' is 'd' in the code...
                    πŸ˜‰
                    My scripts
                      CadFather
                      😲, πŸ˜’, πŸ‘, 😳, πŸ’­
                      THANKS! πŸ˜„
                      only one tool shows the id - the others are ruby calls in .rbs files i cannot access.. 😞
                        googlo
                        πŸ˜„ πŸ˜„ πŸ˜„
                        THX!
                          Gultekinmg
                          inject that into your code..at "icon_observer.rb"
                          >> p "This is SU Bug.."
                          and watch them scroll all the way eternity....
                          • Dan RathbunD Offline
                            Dan Rathbun
                            NO do NOT do this !
                            1. ONLY determine if the return value of the validation proc is MF_CHECKED, MF_GRAYED or MF_ENABLED.
                            2. Keep conditional evaluations (and any other,) at the bare minimum.
                            ALL visible toolbar validation procs are called by the Sketchup application's main loop, each time the user interface needs to be redrawn (including each time the mouse is moved !!) Menu validation procs are called when a specific menu needs to be displayed.
                            I'm not here much anymore.
