    Hide the word "front"
    19 Posts 6 Posters 1.4k Views 6 Watching
      Funny trick! ๐Ÿ˜‰
      It's a pity that don't exist something like for Axes (Enable or Disable)
        Would this be a whole window screen record? If so, you could just leave it there - doesn't bother anyone.
        Otherwise, if you can define the screen record area, just leave that tiny stripe out (i.e. crop it).
          Yes of course ๐Ÿ˜‰
          I had believed that maybe a little trick (or hidden menu) were existing ๐Ÿ˜‰
          • daleD Offline
            dale
            "Front" will only appear when you have chosen that view by choosing it from the icon menu. If you slightly rotate the view it will disappear, and the difference in view is hardly noticeable. Sorry you'll have to scroll the second image to see that there isn't much difference between the views( for some reason it is just uploading bigger).
              NO !
              It's appear in the 3D view ! When rotating the view is exactly face to the observer ! ๐Ÿ˜‰
              • AnssiA Offline
                Anssi
                The only way I see is to rotate your whole model slightly, and then use "align view" in the context menu of a face to place your views.
                Anssi
                  Jim
                  I knew I saw that somewhere...
                  Sketchup.active_model.rendering_options["ShowViewName"] = false
                    remus
                    Thats a pretty useful little trick.
                      That must be write inside the ruby console? โ˜€
                        remus
                        Yeah, just copy and paste it in.
                          Thx for all! ๐Ÿ˜Ž
                            I should already have got(ten) used to not saying "it is not posible"! ๐Ÿ˜ฒ
                            ๐Ÿ‘ โ˜€
                              remus
                              Can you post it pilou? sounds like an interesting project (this crazy animation business ๐Ÿ˜› )
                                I make a "record screen" because the SU export Animation don't work with
                                Animation scene + Proper animation by Morisdov in the same time ๐Ÿ˜’
                                A terrific plug! ๐Ÿ‘ ๐Ÿ‘
                                  remus
                                  Hahaha, thats a pretty cool little tut.
                                    I have no special animation...
                                    but you can load that and see the cube moving inside sketchup
                                    ...but not if you export the animation! ๐Ÿ˜ฎ
                                    Of course you must have the Proper Animation by Morisdov Installed!
                                    If yes for see animation inside Su Press Menu Plugins/ Start Animation observer
                                    Then launch Play animation as usual โ˜€
                                    Some minimalist indeed ๐Ÿ˜‰
                                    and the Splash skp if you know swim ๐Ÿ˜„
                                    Else a little tut (note the "in each scene" is false ๐Ÿ˜ณ : you can address all the positions (1,2,3) from the scene 1 if you want!
                                    But not address more positions than the number of scenes!
                                    http://www.sketchucation.com/forums/scf/download/file.php?id=15717&mode=view
                                    simpletest.skp
                                      A little trick! ๐Ÿ˜‰
                                      As all objects must be a group or a component
                                      For erase a position just explode the group or component then group it or make component again ๐Ÿ˜‰
