How do I create a spiraling tower, please?
Hello there
Thanks to Gaieus help I now have K-Tools "plugged in" as well as the DrawHelix_13.rb to help me with my tower. Still I can´t seem to find a way for the tower to "grow" into the sky the way I want it to. Attached you´ll se a small handsketch of what I want to do.
Any suggestions? I´ll gladly accept any help. Thank you.
Wolf
You could take a look at this:
I think TaffGoch has made a tutorial for this structure.
Regards,
Bob -
Okay, so these are the steps:
- Create a helix with different end and start radii and with a 0 pitch (you can also define the No. of rotations)
- Now create another one with the same radii but with some pitch (the No. of rotations should be the same).
When ready, move it up a bit so that they don't touch each other (otherwise skin rb won't work).
- select both and right click > explode.
- with the selection still on, run skin.rb (note that it doesn't always work properly).
- if you had this nifty plugin, you could get rid of about half of the edges now (OK, I added below)
- finally soften the edges to smooth the surface.
That looks very good. Thanks Gaieus. I´ll try it our later and post my results. I just got word that the draft with the tower got trashed because it has a "biblical negative" feel to it.
Well, it got me in touch with the woderfull world of SU plug ins and
I´ll explore that some more.Thank you guys for your help
Especially you, Gaieus
@bbwolf said:
...I just got word that the draft with the tower got trashed because it has a "biblical negative" feel to it...
Hehe... Maybe you should then start modeling the resurrection or the ascencipon stories
Look around in the Ruby Discussions below - there is some amazing stuff over there!
I just used the time in between two phoncalls from the customer to
check out the tips. Here are my results. Eggzacktelyi what I wanted.I´ll check out the links to the other tips because now, naturally, I
want to be able to walk up and down the tower.
likes to explore
the programms.c.U.
try to use screw_21.rb, It's very quickly to make spiraling tower.
