    Change the color of only one instance
    13 Posts 3 Posters 1.2k Views 3 Watching
      Assuming you are not going to edit the component definition...
      Pick the component instance [let's callits definition Y].
      Use make unique on it [let's call this new version's definition X].
      Chnage the definition of X to make all of its materials the <default> (nil).
      Make the instance's colour say 'Red' - or whatever.
      At the end you simply swap the instances of X with the original definition Y and it looks the same.
      You will have a spare definition hanging around unused - could purge it or empty it's entity list and give it a 'scrap' name...
      • P
        Pout
        Thank you Tig,
        Sounds like the setup we thought about yesterday.
        This is the processflow we were thinking about:
        Change color depending on script result
        1. Get the component definition of the instance
        2. Write this component definition as an attribute in the instance attribute dictionary
        3. Make the instance unique (this results in a new component definition)and give it a name (can we use the auto-component name generator from SU itself?)
        4. Loop through all the entities in the component and set color as red
        Reset color
        1. Check to see if the current instance component definition equals the component definition that is available in the attribute dict of the instance
        2. If there is a difference: give the instance the component definition it has set in it's attribute dictionary.
        3. Delete the 'current' component definition from the component library
        Is this a good way? Thx again
        • GaieusG
          And you were asking for help in the SU discussions πŸ˜„
          • P
            Pout
            lol Gaieus
            Well i thought i asked it in the component section πŸ˜„
            The thread we had going on there was very helpfull to see the posibilities and clear my mind of what exactly i wanted it to do.
            I now have the basics of it but still there are some major issues.
            Here is the code:
            def cinchange
            #--Change the instance--
            #--initialize--
              model=Sketchup.active_model
              ss=model.selection.first
            #--Get component definition name of instance--
              compdefname=ss.definition.name
            #--Write component def. to instance dictionary
              ss.set_attribute 'xdid_dict', 'compdefname', compdefname
            #--Make instance unique (creates new comp. definition)--
              ss.make_unique
            #--Edit the instance (make all entities red)--
              compdef=ss.definition
              ent=compdef.entities
              ent.each {|i|
                      if i.typename=="Face"
                        i.material="red"
                        i.back_material="red"
            def cinrestore
            #--Restore the instance--
            #--initialize--
            #--Get current component definition of instance--
              current_compdefname=ss.definition.name
            #--Get the component definition defined in the attrib. dict.--
              orig_compdefname=ss.get_attribute 'xdid_dict', 'compdefname'
            #--If comp. def. set in attrib. dict. does not equal current comp. def., set the component definition from the attrib. dict. back--
                if orig_compdefname
                  if orig_compdefname!= current_compdefname
                  definitionlist=model.definitions
                  ss.definition=definitionlist[orig_compdefname]
            #--Delete the current component definition from the library--
            #--Delete the attrib. dict. entry from the instance
            The issues are:
            • what to do when there is only one instance of a component present in the model. make unique does not work then. (any thoughts on this?)
            • now for each instance of the same component it creates a new component definition while it could reuse the first one. (dito)
            • get the attribute information out of the instances dictionary
            I don't know if anyone could use the above script and if i need to put it in a plugin or something.
            • P
              Pout
              ok i have my script (almost working)
              def cinchange
              #--initialize--
              UI.messagebox('selection OK')
              #--Get component definition of instance--
              compdef=ss.definition.name
              UI.messagebox('definition OK')
              ss.set_attribute 'xdid_dict', 'compdef', compdef
              UI.messagebox('attribute OK')
              ss.make_unique
              UI.messagebox('unique OK')
              compdef2=ss.definition
              ent=compdef2.entities
              ent.each {|i|
                        i.material="red"
              UI.messagebox('rood OK')
              UI.messagebox('total succes')
              def cinrestore
              orig_compdef=ss.get_attribute 'xdid_dict', 'compdef'
              UI.messagebox(orig_compdef)
              #--If no comp. definition set in the attrib. dict., do nothing--
              current_compdef=ss.definition.name
              UI.messagebox(current_compdef)
              if orig_compdef!= current_compdef
              UI.messagebox('niet gelijk')
              ss.definition=orig_compdef
              The only problem left is how to set the definition of the instance back to the original one based upon the variable orig_compdef which is the name of the definition.
              I have saved the original 'name' of the component definition in the attrib. dictionary cause appaerently it is not possible to save the definition itself.
              Can someone help me on this? --> SOLVED
              Also, could you check if it is possible to make this script 'better'?
              Thx πŸ˜„
              • GaieusG
                True this works that way but how to solve it with ruby, I don't know. Maybe make a temporary copy of it, make it unique then and delete the copy.
                • P
                  Pout
                  Does anyone know how i can give a component definition a certain name?
                  When making an instance unique it automatically adds #1 behind the current component definition name.
                  • GaieusG
                    You can always rename the component (and yes, there have been several feature requests for the Create Component window to pop up when making a component unique).
                    Now how you would do it in ruby, that's a different question πŸ˜„
                    • P
                      Pout
                      Ok i have found that (jeez, i should stop posting when something pops up in my mind)
                      Almost finished.
                      I'll post my code soon.
                        Error 404 (Not Found)!!1
                        (groups.google.com)
